1988 Mustang GT
31.35@55
Couple of intake questions
I'm looking to pick up a new intake, so far its a toss up between the cobra intake and the typhoon intake. I've used the typhoon before, but not the cobra. Does any one have any suggestions? I'm just looking for a cheap temp intake until I can order the trick flow top end kit. I have an explorer intake on it now. But it's a non egr intake.
88 gt 5spd. twisted wedge 170's, tfs stage1 cam, fms 1.72rr, edey rpm air gap intake, holley 650 ultra dp, full msd ignition, BBK full length headers, off-road x-pipe, mac pro-dump exhaust, 4.10 gears, pro 5.0 short shifter |
1988 Mustang GT
31.35@55
Also what size is the throttle body opening on the cobra intake?
89 GT
TB opening on a cobra is 70MM. There's some guys on here that have used the typhoon that can give their opinion. I've only seen pictures of the casting flash and people talking about how it's a crap shoot if you get one that needs a lot of clean up or one that's in decent shape.
1988 Mustang GT
31.35@55
Well im ordering one of the two tonight I just gotta decide.
1991 Ford Mustang GT
cobra and the explorer are almost the same intake. They are a cast version of the tubular gt40 intake. I think you should stick with the intake you have untill you get the trick flow top end kit
1988 Mustang GT
31.35@55
the problem with the intake i have now, is with it being a non egr intake the throttle body mounting pad is cut different on the bottom, and it leaves two holes in the egr spacer. I'm finding all these problems now that i've started working on it
89 GT
Got a pic of the holes? Maybe we can figure out a solution. I've used jb weld on EGR ports in the past.
1988 Mustang GT
31.35@55
i cant get pics, its on the underside of the throttle body.
cant you just replace the egr spacer?
1988 Mustang GT
31.35@55
all the egr spacers i've seen are the same. I'll try to get some pics tomorrow
they have smog legal ones... And just replace the top manifold and get another gt40 its the same as the cobra....
1988 Mustang GT
31.35@55
the lower i have on there now doesn't have the air charge sensor bung in it
89 GT
It's easy as hell to pull the upper off to take pics. Shouldn't take you more than 10-15 minutes at the very most to have the upper completely off.. plus it's good practice, hah.
You can drill and tap the runner for the ACT sensor pretty easily too. I forget the thread pitch and size, but if you plan on actually doing it I can easily find them. |
1988 Mustang GT
31.35@55
oh i can have the upper off in 5 mins. the cars at my work though. so it will be tomorrow
1992 Lx
11.39@119.24
1992 Lx
11.39@119.24
and just plug the act sensor in and leave it laying by the injectors. Tapping the intakes not worth the work, car will run the same either way
1988 Mustang GT
31.35@55
I recently saw a diagram showing the egr valve and fpr having different vacuam sources, and the map sensor having a manifold vacuam. My egr valve and fpr are sharing a vacuam line coming off the driver side firewall tree. Is that ok? also theres no vacuam line hooked up to the map sensor, Would that cause it to run rich?
1988 Mustang GT
31.35@55
There is a tubular gt40 intake on ebay for $500, is it worth it?
89 GT
It flows identical to the intake you have now. Unless you're buying it for looks, it's not worth a penny over what you've got.
1988 Mustang GT
31.35@55
Ok. I wont touch it then.
Threads Similar to: Couple of intake questions
| couple questions | 1987mustanggt | 5.0 Mustangs | 3 | September 22nd, 2010 07:44 PM |
| Couple of questions..... | papemilio | 5.0 Mustangs | 20 | September 2nd, 2010 10:34 PM |
| Got a couple questions | Burn'nRubber | 5.0 Mustangs | 6 | October 29th, 2009 04:44 PM |
| couple of questions about my car | Dennis | 96-98 | 1 | April 20th, 2008 03:52 AM |
| A couple of questions | unhungzero | Visual | 8 | September 10th, 2007 07:48 PM |
