Brakes
Old March 3rd, 2011, 09:24 PM   #1
93 Mustang Gt
velasco98 is on a distinguished road
Brakes
I was driving my car yesterday and my brake pedal felt hard like a rock when I pressed it for the second or third time. Then when I keep driving it gets soft again. Until I press it two or three times. My brakes pads are fine. What could it be?
Old March 3rd, 2011, 09:28 PM   #2
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
sounds like you have a small leak somewhere or you are low on fluid.
Old March 3rd, 2011, 09:35 PM   #3
93 Mustang Gt
No the fluid seems fine but I'll check the lines. Can it also be that the brake fluid is too old?
Old March 3rd, 2011, 10:36 PM   #4
ryanw's Avatar
1991 Ford Mustang GT
may be the brake booster
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old March 4th, 2011, 01:16 AM   #5
93 Mustang Gt
How do I know if it's good? I Also saw a brake booster delete in summit was does it do?
Old March 4th, 2011, 01:40 AM   #6
fogged306's Avatar
89 GT
+1, if the brakes get rock hard then it's either the booster going bad, or it's the booster not getting enough vacuum. Check the vacuum line for cracks and if it looks good it could be your booster on it's way out.
Old March 4th, 2011, 03:19 AM   #7
93 Mustang Gt
I could upgrade my booster and master cylinder for rear disk brakes if it's going bad.
Old March 4th, 2011, 10:54 AM   #8
fogged306's Avatar
89 GT
Does it do that cycle of getting tough to press and then back to normal every time? If it's doing that on a pretty consistent basis, it might be the check valve on the booster. No idea if the one on a fox is accessable or not, but it's worth checking first. It should be right on the booster where the vacuum line plugs in. I'm not in the same state as my car right now or I would go check first so I don't know if this is even a valid thing to check.
Old March 4th, 2011, 01:25 PM   #9
93 Mustang Gt
Yea it does that hard to press cycle and then it gets soft. It does it like everyday now.I'll go check that check valve see if it helps
Threads Similar to: Brakes
Gt brakes to Bullitt brakes eddy21x 99-04 36 January 3rd, 2011 07:38 PM
Stock Brakes to Brembo Brakes... DICobra 4V / SVT 1 September 23rd, 2010 08:17 AM
Bad brakes symptoms but not brakes Stangin94GT 5.0 Mustangs 14 August 25th, 2010 02:58 PM
cobra brakes vs Baer brakes 03SuperchargedGT 99-04 20 May 1st, 2009 05:08 PM
brakes ebo 4356 96-98 4 September 24th, 2008 06:36 PM
