what size extended studs???
Old March 4th, 2011, 12:55 PM   #1
93HatchsBFF's Avatar
1989 LX
12.60 at 109mph
93HatchsBFF will become famous soon enough93HatchsBFF will become famous soon enough
so i was wanted to roll on slicks and skinnies but i dont know what kind of extended studs or what length to get?
1989 LX mustang, 5speed, 108,xxx miles, Mac Longtubes, BBK midpipe, Paxton Novi 1000 6psi, Crappy FMU with 19lb injectors, 373 gears
soon to come
30lb injectors, Blow through MAF, intercooler and tune
Old March 4th, 2011, 04:46 PM   #2
1989 LX coupe 5.0L
89lx is on a distinguished road
i am using stock 95 axles and studs in the back and in the ft i have to run a spacer that bolts to the rotor and then the rim bolts to the spacer using its own five studs
Old March 4th, 2011, 07:07 PM   #3
1992 Lx
11.39@119.24
oh thats what length to run thanks man!
Old March 4th, 2011, 09:04 PM   #4
Duvall's Avatar
91 LX Hatch
Duvall is on a distinguished road
The only ones that I have found require reaming the holes for correct fitment.
Moroso Rear Wheel Studs, 1979-04 Mustang, 5 pack [46180] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
Old March 4th, 2011, 09:36 PM   #5
1992 Lx
11.39@119.24
thank you uu u u u uu beautiful
Old March 5th, 2011, 12:25 AM   #6
I've only ever had them once and they were 3" to conform with nhra's rule... but they are not needed to simply run any type of rim. It all depends on the purpose of the car/tire setup
Threads Similar to: what size extended studs???
need help quick ((studs thread size)) 01brknGT 99-04 3 December 21st, 2009 06:03 PM
Head studs and main studs? tommy023gt 2005 - 2010 14 March 5th, 2009 01:22 PM
extended cowl Rickyracer 5.0 Mustangs 7 August 8th, 2008 01:24 PM
extended warranty??? 05stanggta The Clubhouse 6 May 26th, 2008 01:23 AM
Does a 94 gt have studs in the fender emblem? Snake studs:-( 1911A1 5.0 Mustangs 1 February 24th, 2007 03:00 PM
