1990 Mustang GT
intake manifold HELP!?
I'm about to purchase a new intake manifold. What is the best!? Money is no problem and I'm eventually gonna add nitrous. I was looking at the edelbrock rpm series, the bbk ssi (which comes with free high flow fuel rails), and idk anything about trick flow and professional products. Help ordering soon! Also buying a underdrive pully kit, BBK CAI, SCT chip, and 70mm throttle body.
1990 stang gt
comes down to what you wanna do with the car. i personally like my rpmII.
1990 Mustang GT
Add nitrous and keep it N.A...no super or turbo chargers.
1990 Mustang GT
Gonna get a Ford racing BOSS 347 or 351 eventually but all my parts should transfer.
89 GT
There is no best for every engine. There's a best choice or choices for your specific car. What's been done to the car so far?
If you get an intake for your 302 now, the lower will not work if you decide to go with a 351 based engine later on. ... and don't touch the SSI. garbage intake for any combo. Your distributer will not transfer and neither will your headers if you do a 351 swap. And you will need a swap oil pan as well. If you go with a boss block and do a 347, make sure it's a 4.125" bore 3.25" stroke 347 and not a 4.030" bore 3.4" stroke. The cylinder walls on those blocks are .350" shorter than stock and will leave less skirt in the bore making them more prone to piston rock if you use a 3.4" stroke. Last edited by fogged306; March 5th, 2011 at 04:44 PM. |
Threads Similar to: intake manifold HELP!?
| Swapping a 98 V6 intake manifold with for a 99 V6 manifold | 98mustang | V6 Mustangs | 6 | November 20th, 2010 11:20 PM |
| Non PI intake manifold vs Aluminium crossover Intake manifold | cedp83 | 96-98 | 6 | September 10th, 2010 03:45 PM |
| Non PI intake manifold vs Aluminium crossover Intake manifold | cedp83 | 99-04 | 1 | September 9th, 2010 02:04 AM |
| BBK SSI Intake manifold | Timm10221 | 5.0 Mustangs | 13 | October 30th, 2007 09:46 AM |
| Help Intake Manifold | stang94 | 5.0 Mustangs | 8 | October 26th, 2006 01:38 PM |
