96 spindles on a foxbody
Old March 5th, 2011, 05:13 PM   #1
Look Ma! My First Post!
1994 GT
justang94 is on a distinguished road
Talking
Okay,
I know the quesiton has been asked many many times and there are alot of thoughts out there on this. I just completed a 5 lug conversion on my car and used 1996 non abs v6 spindles in the front and it did not widen the track width. In fact the part number cross referance manual at the junk yard said that 96 non abs front spindles are the same as 94 and 95 spindles.
I just thought I would share since I couldnt find the answer any where before I tried it.
Bump Steer myth.
When i got it all back together and done (I also lowered it) the spindles work great with out a bumpsteer kit. The tie rod is parrallel to the A-arm.
Hope this helps.
Old March 5th, 2011, 06:44 PM   #2
EscortSportage's Avatar
1989 Mustang GT 5.0
ekkk, use 94/95 stuff!
94/95 widen just a little more, think its 1/4 of an inch
the 96 widened it 1/2 inch i believe
but since the v6 non abs are same as the 94/95 u should be good, (never knew that)
i did a 5 lug 94/95 stuff on my fox rear disc brakes !!!
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Threads Similar to: 96 spindles on a foxbody
88 spindles Bman 5.0 Mustangs 0 April 4th, 2010 06:47 PM
67'-68' spindles on a 66'??? stangjr Classic Mustangs 2 March 2nd, 2010 07:08 PM
4 Cyl. Vs V8 Spindles Caddpro 5.0 Mustangs 3 March 7th, 2008 01:48 PM
Spindles spdfrek General Tech 0 January 14th, 2008 10:38 PM
SN 95 spindles Jojogunne 5.0 Mustangs 6 January 4th, 2008 06:55 PM
