95 Build
Old March 5th, 2011, 09:10 PM   #1
97gtmustang's Avatar
1995 Mustang GT
97gtmustang is on a distinguished road
95 Build
I gotta a 95 GT Mustang
So far-
*75mm throttle
*90mm MAF
*CAI
*9mm Wires
*3:73 gear
*Full Exhaust
I also have 26lb Injectors, Long Tube Headers just these 2 not installed
_______________
I want to do the Trick Flow Track Heat Package.
the 170cc Twisted Wedge heads on the TFS Stage 1 cam, with the Track Heat Intake lower and upper. Also in the kit comes gaskets, timing assembly, rockers, pushrods, and ill get some valve springs.
Im not going down bottom end, i only have 60,000 miles on my car, so no 331 or 348 for me. I know its alot of money to spend, but this is the car of my dreams, the engine i wanted. So if im missing anything, or if anybody has any experience with this kit, would be greatly appreciated.
1995 Ford Mustang Sn95 Canary Yellow
Building a 347 Stroker with a Vortech V1 Blower
Old March 5th, 2011, 09:19 PM   #2
fogged306's Avatar
89 GT
Everything looks good, except I wouldn't go with a TFS cam. They're not a whole lot better than the letter cams when it comes to the grind and quality of the cam. Check out the anderson cams and give them a call and see what they recommend. Much better cams for a little more money.
Old March 5th, 2011, 09:20 PM   #3
1992 Lx
11.39@119.24
tf 170s
trickflow r intake
tfs 2 cam
thats how their combo should be sold
Old March 5th, 2011, 09:38 PM   #4
1995 Mustang GT
The tfs 2 has a a lift and duration of a drag car, i think the tfs2 has 10:1 comp
Im really pumped about doing this build, becuase im Taking Engine Repair at my College, and learning how to build an engine, so im not just some kid posting useless stuff.
@fogged- thanks man, there are plenty of cams out there deff! Just no FRPP cams, lol
Old March 5th, 2011, 09:41 PM   #5
1992 Lx
11.39@119.24
wut
Old March 5th, 2011, 09:42 PM   #6
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Whaaaaaaa????? Sorry dude, but that's funny. That's the lift of the slowest race car on earth ....lol
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old March 5th, 2011, 09:46 PM   #7
1995 Mustang GT
oops, still reading wrong, Minimum 10:1
TrickFlow Website:
TFS2
Race; rough idle, strong top-end power, 3,000-3,500 rpm stall converter, 3.90-4.11 gears. Calibrated mass airflow meter required. Compression: 10:1 minimum.
thats more of a drag build?
Old March 5th, 2011, 09:47 PM   #8
1992 Lx
11.39@119.24
thats all blah blah blah according to that shit my box intake would mean I gota shift at 8k
Old March 5th, 2011, 09:53 PM   #9
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
TrickFlow Website:
TFS2
The TFS 2 is a small cam. Very streetable.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old March 5th, 2011, 09:54 PM   #10
1995 Mustang GT
Thanks for ur help man!
wtb having stock block>?
Old March 5th, 2011, 09:55 PM   #11
1992 Lx
11.39@119.24
wut
Old March 5th, 2011, 09:57 PM   #12
1995 Mustang GT
Is it streetable enough for me to use on stock block?
Old March 5th, 2011, 10:02 PM   #13
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
The only thing that really affects the block, are horsepower and RPMs. You won't make enough power N/A with a TFS2 cam to worry about splitting the block. Unless you get a custom cam, which is best, I'd listen to what fogged306 and look at Anderson cams. I know several people that have had great luck with them.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old March 5th, 2011, 10:05 PM   #14
1992 Lx
11.39@119.24
I think the b51 is close as shit to a tfs2, just billet
Threads Similar to: 95 Build
Help me build! RiceBurner92 99-04 20 September 7th, 2010 01:39 PM
Need someone to build me something Till Chopshop 0 October 9th, 2009 06:13 PM
4.2 build SleeperStang88 V6 Mustangs 4 October 8th, 2009 11:04 PM
help me out with a build White Thunder 5.0 Mustangs 24 November 4th, 2007 11:31 AM
