Engine Build - Page 3
Old May 5th, 2011, 03:13 AM   #41
Ohsplat's Avatar
1983GT
No motor or trans
Ohsplat is on a distinguished road
Send a message via Yahoo to Ohsplat
Thats controlled by the governor on the trans or the Ecm. A tune, chip or engine management system could change that. If you make it shift to high before you install the shift kit you could burn up the clutches. I really would think about putting in a C4 or a heavy duty AOD like a streetfighter. The AOD as it comes from ford is the worst transmission ever designed and is very weak. I had less then 300 hp at the crank in my convertible mustang and if I floored the car in OD after about 65 the band would slip. You could stay in D but then you need to have a engine that can handle the rpms you would be making at higher speeds.
Old May 9th, 2011, 09:10 PM   #42
Lariat85 is on a distinguished road
Ok, I found a new cam I'm goin with.. Its the Comp 35-255-5. It's a 351W cam
Intake Duration at 050 inch Lift 210
Exhaust Duration at 050 inch Lift 214
Duration at 050 inch Lift 210 int./214 exh.
Advertised Intake Duration 254
Advertised Exhaust Duration 258
Advertised Duration 254 int./258 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.478 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.485 in.
Valve Lift with Factory Rocker Arm Ratio 0.478 int./0.485 exh.
Lobe Separation (degrees) 114
Old May 19th, 2011, 08:33 PM   #43
Oh, can you get a different governor for the trans? I would like it to shift at about 5,000 rpms.
I plan on having the AOD rebuilt..and I'm putting a shirt kit in it, and a constant press. valve body.
Old May 28th, 2011, 01:40 PM   #44
Old May 28th, 2011, 04:29 PM   #45
fogged306's Avatar
89 GT
Is your engine a stock flat tappet?
Old May 31st, 2011, 04:32 PM   #46
Yeah, it is.
Also...what pistons should I go with? Was thinking about going with hypertuenic.
Threads Similar to: Engine Build
Engine build Q's. PUNISHER08GT 2005 - 2010 14 October 15th, 2010 05:54 PM
Engine build 302Boss 5.0 Mustangs 19 June 10th, 2010 10:40 PM
Plz help me with my engine build. Texas01GT 99-04 23 October 18th, 2009 04:37 PM
Engine Build Up or Engine Replacement... OcOnnor220 99-04 8 July 27th, 2008 03:54 PM
Need Help With Engine Build! 94stang 5.0 Mustangs 17 January 26th, 2008 07:05 PM
