1991 Mustang GT
Sloowwwww
Weird headlight problem
Tonight I was driving home and decided to get on her a lil bit so I switched my brights on and for a split second my headlights went out but my ambers stayed on and then the brights came on. Should I be worried about this?
Black 'Stang Crew #1337 |
1990 mustang gt
It's either the mf switch, or the headlight switch got hot. Mine used to do that with the low beams until I added relays
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
89 GT
^ Yep. I would lean towards the multifunction switch if it happened at the exact moment you flipped your highs on. They have a tendency to go bad. The headlight switches do burn up in these cars too, but I would guess the contacts aren't making a good connection in the multifunction by the way you described what happened.
Quick way to temporarily rule out the headlight switch is to pull the switch and look at the connector and where the connector plugs in. If it looks discolored and/or bubbled from heat, replace it. |
1992 mustang Lx
13.4@ 106
<y old headlight switch got so hot it literally melted about a quarter of my connector! It was nuts! I finally replaced it and all was good. I replaced both the multifunction switch and the headlight connectors. Not too bad if you have a yard with some foxes to borrow from.
![]() 1992 5.0 lx_soon to be powered by a m122 GT500 supercharger
1993 Mustang GT
Same thing has been happening to my car. Thanks for the tip.
94 5.0 302 gt
in the making
yes the mf switch (turn signal switch) ford has this problem in a wide range of older cars, trucks.
#7 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
Did you have the fog lights on at the same time? There is a known problem with that as well.
Threads Similar to: Weird headlight problem
| HID Headlight Problem | rubicon26 | 2005 - 2010 | 6 | January 30th, 2011 11:05 PM |
| Weird problem to have | gotn20 | 5.0 Mustangs | 8 | February 5th, 2009 11:28 AM |
| Headlight Problem | moneygreenstang | V6 Mustangs | 15 | June 29th, 2008 03:01 PM |
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 12:03 PM |
| Headlight Problem | ridebmxfbm | 5.0 Mustangs | 23 | May 23rd, 2007 11:53 PM |
