94 mustang,88 mustang
n/a
removing the heater
ok so my heater on my 93 doesnt work so i wanted to remove it completely to shed a few pounds can anyone guide me to what i have to remove
thanks |
89 GT
The entire dash has to come out. It's not that bad, but it will take some time. There's 3 or 4 nuts that go through the firewall too that have to be removed. You can't miss them on the firewall, they're nuts with big washers attached. The center console comes out first, then the dash, then the heater.
BTW, it barely weighs 15lbs. I pulled mine and was surprised at how little it weighed compared to other heater cores I've removed. |
89 FOX/01 WS6
0@0/13.1@106
It does take some time but it will also free up some space under the dash. I used it to mount my relay panel and will be mounting the ignition components there also.
1992 mustang lx 5.0
if you just wanna take out ur heater core, id save the time and hassle and re-route the heater hoses to bypass it...
However, I thank you, for this pen and ink ammunition.. Thank you for the inspiration! |
1991 Ford Mustang GT
do you know whats wrong with the heater ? does it leak? does the fan not come on ? What. You should fix it... Having defrost id think would be a must no matter where you live
#6 | |
1992 mustang Lx
13.4@ 106
You don't wanna have to stop get out and wipe your windshield down every time it fogs up! My old heater core started draining fluid into the car so I had to replace it. I got it out without taking the entire dash out. If you loosen the dash everywhere and take out the bolts on the passenger side and center you should be able to maneuver the heater box out.
![]() 1992 5.0 lx_soon to be powered by a m122 GT500 supercharger
n/a
the hosses that go from the engine compartment trought the firewall have been cut
1992 mustang Lx
13.4@ 106
You can easily replace those and if the pipes to the heater core were cut as well you can just replace the heater core along with the hoses and you should be set.
You can fix your heater with almost the same amount of effort you will have to put forth to remove it. To me it makes no sence in deleting your heater system.
Threads Similar to: removing the heater
| Removing heater core loop/Simplifying engine | sniperd | 5.0 Mustangs | 18 | November 19th, 2009 08:00 PM |
| removing heater core, need help plz | 91cobra5.0 | 5.0 Mustangs | 10 | March 24th, 2008 12:31 AM |
| Need Heater Help | 91cobra5.0 | 5.0 Mustangs | 1 | February 18th, 2008 05:40 AM |
| AC & Heater now that it is winter, my heater doesn't wor | Kingcater | 5.0 Mustangs | 13 | January 22nd, 2008 12:33 AM |
| heater | 232stang | V6 Mustangs | 12 | December 1st, 2006 05:27 PM |
