battery relocation - Page 2
Old March 10th, 2011, 08:42 PM   #21
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
the hammer tool method will work fine. I have used it on my car and it works fine. It is a much better connection than the bolt on crap that was on there before. The solder method looks good too.
If you have your quad shocks removed, run your ground out to one of the quad shock bolt holes and hook it up there.
0 ga. FTW!
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
Old May 19th, 2011, 12:30 AM   #22
force-fed-snake's Avatar
93 GT
force-fed-snake is on a distinguished road
so how many guys actually make the effort to move the solenoid to the pass side? i mean leaving in the stock location would be an easy 8-10' of un needed cable... not to mention moving it would get it a lot closer for a 3g alt wiring
Old May 19th, 2011, 01:44 AM   #23
PeterMartin is on a distinguished road
Latest cars
It is advisable to buy a new kit instead of trying the risky alternatives for it.
Old May 19th, 2011, 07:49 AM   #24
fogged306's Avatar
89 GT
The solenoid is also a junction block for some 12v sources in the car. If you moved the solenoid, you would either have to extend all those wires over to it too, or put another distribution block in it's place. At that point, you might as well just get an SN-95 starter with the solenoid built into the starter and run it like that. That's how I did my wiring.
Old May 19th, 2011, 01:11 PM   #25
93 GT
that sounds like a very viable option.
im extremely anal when it comes to wiring... so i know when i actually touch the factory harness, it will all get cleaned up and hidden anyway... so this may just be the perfect "temp" solution until i want to spend some serious time on it.
Old May 19th, 2011, 05:27 PM   #26
fogged306's Avatar
89 GT
It's not that hard to do if you know wiring. I sat down with an EEC pinout print-up and a few spools of wire and had everything hidden inside a days worth of work, not including removing and replacing the interior and body panels. I also trimmed any wiring I didn't need and re-wired the engine harness to come out of a hole I drilled just behind the intake so everything is hidden from sight except the wires running along either side of the lower that plug in to all the sensors.
Old May 19th, 2011, 05:32 PM   #27
93 GT
i will be doin a coyote 5.0 swap after the summer is over.... so at that time i will focus on all of the engine compartment clean-up. for now though i just want to get the battery off the nose and in its new home behind the seats.
Old May 19th, 2011, 05:36 PM   #28
fogged306's Avatar
89 GT
Nice. I've been wanting to do a modular N/A set-up lately. Love to see how your car turns out.
Old October 27th, 2011, 08:27 PM   #29
1990 5.0 Smokin' AOD LX
14.27@100.77
Siegedg505 is on a distinguished road
I know i am reviving and older thread, but I am planning to do the battery relocation, but the NHRA rules say that i would need an externally mounted kill switch. How many of you guys are running a similar switch? And where?
90 Mustang LX 5.0 T5 swapped,Mac CAI,intake,Timing,E-Fan,headers,H Pipe,Dumps,Gears,Control Arms,and diet
http://www.fictionalversus.com/index.php my second love
Threads Similar to: battery relocation
Battery Relocation Help 02'TrueBlue 99-04 40 December 8th, 2010 11:53 AM
battery relocation Ryguy33 99-04 7 July 2nd, 2010 02:12 PM
DIY Battery relocation ?? SilverGT04 99-04 41 June 25th, 2009 11:27 PM
Battery Relocation F8L GT 99-04 7 October 11th, 2008 12:19 AM
Battery Relocation 90Stang 5.0 Mustangs 11 April 16th, 2007 07:31 AM
