Rear End Death whine?
Old March 9th, 2011, 02:37 PM   #1
1990 LX
slow
oneslow3000gt is on a distinguished road
Hey guys so I was out cruising around yesterday and while I was on the the freeway, Every time I gave it so gas I would get the loud Whine from the rear of the car...As I am new to RWD Car's anyone want to take a stab at what it could be? It only happens in third gear and up. It sounds like gears of some sort. thanks
P.S. the forum search engine sucks, Got so many non-related hits....
1992 Mitsu 3000gt vr-4: DR650 + supporting: 465AWHP
1990 mustang lx 5.0: operation no squeak; check!
operation bust the stock block; underway..
Old March 9th, 2011, 03:17 PM   #2
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
Your cars automatic or manual?
Old March 9th, 2011, 03:17 PM   #3
1990 LX
slow
5 speed.
Old March 9th, 2011, 04:01 PM   #4
91 Mustang GT
1991 sliver GT
Mabe worn rear? U would have too pull it to inspect it
Old March 9th, 2011, 05:20 PM   #5
fogged306's Avatar
89 GT
You sure it's coming from the rear of the car? That sounds more like a transmission issue than a rear-end issue.
Old March 9th, 2011, 05:28 PM   #6
PsyAbe's Avatar
'92 LX
PsyAbe is on a distinguished road
Send a message via AIM to PsyAbe
I have that same problem in my 98 Grand Cherokee though it's a 4wd. In my case it turned out to be a loose pinion
Old March 9th, 2011, 05:43 PM   #7
1990 LX
slow
Although I know the tranny Is pretty beat up, I am almost positive it is coming from the rear of the car.
so...pull the rear end and pop that sucker open, look for worn down, chipped or strait out missing gears then?
I guess this is going to be a weekend project then.
should be interesting. I Hate working on drivelines though.
Old March 9th, 2011, 06:11 PM   #8
fogged306's Avatar
89 GT
You don't have to pull the rear. Just pop the diff cover off and give it a look. Check and see what the oil looks like, see if there's any shavings in it or if it's real thin fluid. I'm not really all that good with rear-ends so I can't really tell you what to look for other than what you mentioned, but I will say that when you re-fill it, you need to add a friction modifier to the gear oil.
Old March 9th, 2011, 10:53 PM   #9
1990 LX
slow
Well thats good news! Will do and thanks for the info
Old March 9th, 2011, 11:20 PM   #10
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Silver oil will be a bad thing!
Old March 10th, 2011, 01:10 PM   #11
1990 LX
slow
yea it will, I spun a bearing in my 3000gt, nothing like seeing a bunch of metal flakes in the oil.
Old March 10th, 2011, 02:02 PM   #12
HMERacing's Avatar
89 FOX/01 WS6
0@0/13.1@106
HMERacing is on a distinguished road
You can also take the driveshaft loose and check to see if the pinion has any obvious play. Check fluid levels too!
Mike
1989 Mustang LX, 2001 Transam WS6
Originally Posted by 302Army187 View Post
I'm going to install an U pipe.
bitch is going to re route the exhaust pulse back out of the intake between intake pulses.
Old March 10th, 2011, 02:08 PM   #13
I would say if it were your ring and pinion(gears) it would make the noise at all speeds just increase volume with rpm.. The gears could be setup too loose/too tight or beyond the point and needing replacement.
Threads Similar to: Rear End Death whine?
Death to the stock rear end. ia07gt 2005 - 2010 11 February 12th, 2010 04:00 PM
Anyone ever had a whine from rear gears? 1Badsnake 4V / SVT 21 August 14th, 2009 09:56 PM
rear end whine? ZoomZoomMFer 99-04 12 June 23rd, 2009 08:54 AM
rear end whine 94stangGT50 5.0 Mustangs 7 April 17th, 2008 01:22 AM
Found out what the whine was coming from the rear end... Fox2102 V6 Mustangs 7 December 7th, 2007 07:38 AM
