Please help with the heat
Old May 12th, 2006, 09:33 AM   #1
tdurbin is on a distinguished road
I have an 88 gt conv. My Mods are on an original 302 block.I have upgraded to mass air, installed gt 40 heads w/roller rockers and hardened push rods. gt 40 intake upper and lower and an E cam. There is a new water pump and radiator but the temp keeps climbing to around 260 on normal driving, highway and street. The timing has been checked and is good. The thermostat is a brand new 180 degree. The only thing I noticed is that the overflow tank has a small crack around midway up. Could this be causing my problem or something else? Any help would be appreciated.
Old May 12th, 2006, 09:50 AM   #2
ck the clutch fan, also make sure it has the correct rotation water pump and the belt is routed the correct way.
88 Mustang Coupe
www.rickscarcare.net
Old May 12th, 2006, 09:54 AM   #3
Clutch is new. I forgot to mention the smog pump is deleted and fan is routed correctly. As for the water oump I had someone elde install for me I didn't have any time to work on it, he knows a lot about stangs so i know is has to be correct flow. Even he has no idea what it caould be.
Old May 12th, 2006, 10:03 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Did the problem start after you did the heads? Could be air in the system.
Old May 12th, 2006, 10:10 AM   #5
since the heads were done they were checked twice gaskets are correct as well as compresion.
Old May 12th, 2006, 08:08 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Gasket sealing has nothing to do with it. When you drain the cooling system and refill it air pockets develop. If you don't get them out you will have over heating issues. Air pockets are very common after doing a head swap and are not hard to get rid of.
Old May 13th, 2006, 02:32 AM   #7
stang fanatic's Avatar
stang fanatic is on a distinguished road
RUN CAR TO 268? AN SHUT OFF. GRAB FAN AND SEE IF STIFF OR LOOSE TO SPIN. IF LOOSE OR EASY...CLUTCH NO GOOD. OR IS IT A FLEX FAN? DO YOU STILL HAVE THE SHROUD ON???
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old May 14th, 2006, 12:54 AM   #8
If i have a crack in my overflow tank would that create air pockets in my cooling?
Old May 14th, 2006, 01:10 AM   #9
no.....but wont suck back coolant when needed (in theory).
Old May 14th, 2006, 02:06 AM   #10
IcantDo55 is on a distinguished road
What gauge are you using for the temps?
260*?
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old May 19th, 2006, 02:21 AM   #11
Hollywood is on a distinguished road
"no.....but wont suck back coolant when needed (in theory)."
If your street stang is pulling coolant from the reserve, then your in trouble on a different level.
Run the car to about 240 on the gauge, turn the headlights on full way, then get under the passenger side and see if there's any white smoke...
Let it rest, then repeat with the headlights off.
If you're not getting any smoke, then your not vaporizing your water flow.
Can your friend do a controlled environment test to see if the car begins to ping-out after you break 270?
It could just be an electrical mis-read by your gauge.
Old May 19th, 2006, 09:38 AM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Why would you be in trouble? The closed system is designed to push coolant into the reserve tank and pull coolant back out. I don't see what "trouble" you are refering to.
Old May 19th, 2006, 12:15 PM   #13
If your stock parts are working, you'd be in trouble.....you'd be in the twighlight zone.
Threads Similar to: Please help with the heat
driving a V-6 in the heat JASonic V6 Mustangs 19 May 7th, 2007 07:42 PM
Heat Release snailstang 96-98 1 February 16th, 2007 10:51 AM
Heat Plates ThePonyExpress V6 Mustangs 16 February 12th, 2007 01:57 PM
no heat hmotes 5.0 Mustangs 8 January 15th, 2007 05:24 PM
Heat / Air terribleonexx88 5.0 Mustangs 3 October 19th, 2006 01:09 AM
