5.0 Vacuum problems.
So here recently our motor in our Lincoln MKVII popped, given its my parents only car currently we had to rush and find a motor, so we got a regular 5.0 for a great price.
Well we swapped everything in thought we had everything right and something is messed up in the vacuums, I cant find a good enough picture. But the main thing is I know we have the FPR right, and the pcv, but Im not too sure about the others. Can someone explain where everything else goes (where the other hoses are and where they go) ![]() Thanks!
1995 Nissan 240sx. Coilovers, intake, full 3in exhaust, RUCAS, J30vlsd, 1 piece drive shaft, Q45 Front brakes, short throw, subframe collar bushings. |
Anyone? This is turning into a huge headache, Needs this sonofagun running ASAP
I can't put up pics with 0 posts. Let's try again.
I'm not familiar with a Lincoln engine bay, but in my 89 Mustang, the CANP line (blue writing) runs to a canister purge valve then to a charcoal canister on the lower/front passenger side
![]() vacuum tree (red writing) on firewall above brake booster, big hose on left labeled S ![]() EGR tree (pink writing) ![]() ![]() ![]()
1991 Ford Mustang GT
damn you have all the vacuum diagrams. I need to make a note of these.
Cause of Death, and H.P. Lovecraft rule!
Cause of death and world demise... good albums
Threads Similar to: 5.0 Vacuum problems.
| Vacuum problems | JasonT1124 | 99-04 | 6 | July 9th, 2010 11:31 AM |
| low vacuum?! | Arian5.0 | 5.0 Mustangs | 11 | April 21st, 2009 03:39 PM |
| Vacuum Qs | hmargov1 | Classic Mustangs | 3 | February 14th, 2009 06:05 PM |
| vacuum sec vs DP | GT87Stang | 5.0 Mustangs | 1 | February 13th, 2009 05:20 AM |
| vacuum... | sivart | 5.0 Mustangs | 22 | July 31st, 2007 11:02 PM |
