LinkBack (2) | Thread Tools |
#1
94 mustang,88 mustang
n/a
gt40 intake/gt40 heads
how much horsepower will some 93 cobra gt40 heads and gt40 intake be pushing on a 93 mustang
1992 Mustang GT
30ish
3.73's, GT40P Heads, GT40 upper and lower, underdrive pulleys, TFS 1 cam, double roller timing set, SCT 4 Bank "Eric with a mustache and Mustang Eric?" Last edited by ESwanny11; March 10th, 2011 at 06:22 PM. |
n/a
would it be worth trading some black 17x9 with a polished lip with good tires for some heads with roller rockers ready to put on
89 GT
What are the rims worth? GT-40 parts are dirt cheap. You should be able to find a used set for $200 and an intake for $150 or less for both. You can find an entire explorer engine for around $350-$400 with GT-40 stuff on it and sell the shortblock to recoup some money and end up paying even less. Decent rims with good tires aren't a good trade at all.
1992 Mustang GT
you could probably find some gt40 heads for around 200-300, depending on how hard you search. I bought my gt40p heads ported, milled, and fresh springs for 300. So if you can sell those wheels for 600 or so you could buy some heads and supporting mods like a cam. IMO
3.73's, GT40P Heads, GT40 upper and lower, underdrive pulleys, TFS 1 cam, double roller timing set, SCT 4 Bank "Eric with a mustache and Mustang Eric?" |
n/a
yeah so im better of selling my rims separate then where can i find some heads to buy in houston
91 Mustang GT
1991 sliver GT
Check craigslist. Idk if you can post in the classified section yet on the form.
1992 Mustang GT
also check corral
1991 Mustang LX 5.0
And the junkyard
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
n/a
other than the plugs what is the difrence in the p heads
1991 Ford Mustang GT
I dont think the P heads have the smog ports on the back. im sure theirs other stuff, but im unsure of what they are. Im told the P heads are better then the regular gt40 ones
1992 Mustang GT
you need to make sure you get headers that fit P heads. Not sure wwhich ones fit, but I'm sure someone will chime in and tell you. Because of the spark plug angle you run into some clearence issues
n/a
well if i have to get headers i might as well save the money and get better heads i want some longtubes that means i will also have to buy a mid pipe,and ive heard the non p are better
89 GT
The P heads will make more power. The plugs are centered more in the chamber for a more efficient burn. I believe the chambers are shaped differently too. That's why they're a pain with headers sometimes because they're not in the normal plug locations. I've never run them so I couldn't tell you first hand, but I've seen a lot of guys say you just need 90* boots and they work with most headers.. Either way, you've got the right idea about saving up for good heads, I'd stick with that plan.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/207938-gt40-intake-gt40-heads.html
| Thread GT40 Heads Bare | Corral.net: Ford Mustang Forums | BoardReader | This thread | Refback | November 3rd, 2011 05:23 PM | |
| Thread GT40 P heads | ClassicBroncos.com Forums - 66-77 Early Ford Bronco Discussion Forums | BoardReader | This thread | Refback | June 2nd, 2011 03:24 PM | |
Threads Similar to: gt40 intake/gt40 heads
| GT40 heads and intake help | Drick | 5.0 Mustangs | 35 | January 27th, 2011 06:41 AM |
| gt40 heads/ intake | LukeG15 | 5.0 Mustangs | 6 | January 23rd, 2011 05:44 PM |
| Cam suggestions with GT40 heads/intake. | timalev | 5.0 Mustangs | 25 | October 18th, 2010 10:22 AM |
| GT40 Heads Intake | shadowgames81 | 5.0 Mustangs | 22 | June 30th, 2008 07:43 PM |
