95 converted to carb need help with irratic RPM while drivin
Old April 25th, 2007, 09:31 PM   #1
Stang955.0 is on a distinguished road
About 10 - 15 minutes after the car gets hot my RPM will Jump up about 3000 and then drop down to the point of almost stalling even when its in gear and i'm driving. Can anybody help me?
Old April 25th, 2007, 10:04 PM   #2
angermgt's Avatar
angermgt is on a distinguished road
could be a lot of things. sounds like too much fuel and not enough fuel. do you have a fuel pressure gauge? if not get one. why did you go to carb?
490whp/432wtq, V2 13lbs. boost, 3.33 pulley
Old April 25th, 2007, 10:07 PM   #3
bought car this way and i do have a fuel pressure gauge its at 6 psi i checked out the gauge wil that was happening and it always stayed the same
Old April 25th, 2007, 10:26 PM   #4
angermgt's Avatar
did it do this when you bought it or did this start happening after you had it a while? i'm not real familiar with carb. but had them a long time ago and they were a real pita to get right. try adjusting the carb when its running and see if you can get it to do something different. doesnt sound like idle screw because it does it when driving. try the mixture or mabey try cleaning the bowls. take carb apart and soak in cleaner.
Old April 28th, 2007, 03:40 PM   #5
alright thank you will try
Old April 30th, 2007, 12:34 AM   #6
tag team's Avatar
tag team is on a distinguished road
hey you need to get your fuel pressure up to 8lbs & if that dont help it there is a old school trick that might help. with the breather of & car running pull up your rpms some were close to 3500 and take your hand &
cover as much of the top of the carb as you can do this a few times what it does is pull trash thru it if there is any . it might help
all 4 one & one 4 all
Threads Similar to: 95 converted to carb need help with irratic RPM while drivin
BIZARE DRIVIN LAWS Luvdmustang The Clubhouse 2 September 13th, 2007 11:50 PM
I converted !! nohobandit 2005 - 2010 39 January 25th, 2007 10:56 AM
Drivin Me Nuts! Stangzilla 5.0 Mustangs 6 November 3rd, 2006 04:20 PM
Drivin Tunes? WaRHorse 99-04 26 October 1st, 2006 06:52 AM
need help , MAP on MAF converted 86 gt chadjones99 5.0 Mustangs 0 August 31st, 2006 01:48 AM
