1994 mustang cobra
window issue
so i put my 94 cobra away before winter and everything worked just fine. i took it out and only my driver side window wont work. the passenger window works just fine. i checked the motor when i took it out and it works perfect. the window is well greased and slides fine. fuse is also fine. switch works perfect. any ideas please help
thanks |
94 mustang,88 mustang
n/a
mine did that once but it only did it when i had my key turned halfway everytime i turned it on it worked fine, after a few days it went back to normal and it worked with the key halfway
1990 mustang gt
It might not have a good ground on the switch
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
1990 GT
unknown
I had a similar problem on my fox, pulled the panels to inspect switch connections. Everything looked good so i used some dielectric (sp?) grease on the plugs/switches and haven't had an issue since.
91 Notchback
You also have to think that just because the motor may work with no load doesn't mean that the motor is strong enough with a load.
May not be your issue just my .02 cents. |
I've had three Ford cars with the same type of motor not work and when I took the motor out and looked at it, it started working again. Must be dead spot on the rotor, brushes were a little corroded, bad connection or some combination of those.
1994 mustang cobra
thanks for all the info, it was weird, i took it to two of my buddies shops were one specializes in full restoration of muscle and hot rods.. he couldnt figure it out. so i basically said whatever and put the door panel back on and bam it works! i dont know its weird but it is something with the ground. because they hooked up a tester and it was giving a weird reading from the ground but we couldnt figure it out. oh well it works now so im happy
Threads Similar to: window issue
| Window issue | mustang_gtr_99 | 99-04 | 11 | October 18th, 2011 12:45 PM |
| Window Issue | DAMNitzHENRY | 2005 - 2010 | 6 | January 11th, 2010 11:32 PM |
| window issue | HBK_2007 | 96-98 | 3 | March 19th, 2009 06:24 PM |
| Power Window Issue | sjr56 | Audio/Video | 2 | May 28th, 2008 04:07 PM |
| 05 window return issue!.help! | 78mach1 | V6 Mustangs | 12 | January 20th, 2008 07:15 PM |
