fuel pressure
Old March 10th, 2011, 10:02 PM   #1
v8 offroad is on a distinguished road
fuel pressure
Have a 5.0 with ecam 24lb. injectors.What fuel pressure should I be running?
Old March 10th, 2011, 10:28 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
If thats all you have id say....stock fuel pressure
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old March 10th, 2011, 10:44 PM   #3
fogged306's Avatar
89 GT
You always want stock fuel pressure with EFI. 39PSI at idle with the vac line off. The computer has tables it uses to calibrate how much fuel to spray. The tables are built in at 19# injectors with 39lbs of pressure behind them so it knows exactly how much fuel will spray for .xx amt of time the injector is open. If you change fuel pressure, it doesn't know how much fuel it's spraying anymore. If the MAF or EEC aren't calibrated for the 24# injectors then it's a guessing game though.
Threads Similar to: fuel pressure
fuel pressure M L Struck 96-98 4 January 26th, 2009 12:07 PM
Fuel Pressure Regulator Leaking Fuel Buttaz V6 Mustangs 4 August 17th, 2007 11:41 AM
Fuel Injectors/fuel pressure 00silvergt 99-04 4 August 2nd, 2007 09:54 AM
No fuel pressure, Fuel gauge went above full and stayed. woodz72 96-98 6 July 10th, 2007 06:58 PM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 03:31 PM
