Gas smell
Old March 11th, 2011, 12:09 AM   #1
brandon444's Avatar
91 Mustang LX 5.0
brandon444 is on a distinguished road
Gas smell
Any ideas why every morning I get in my car and it smells like raw unburnt fuel?
Old March 11th, 2011, 02:37 AM   #2
1986 Mustang LX
hoffmabo is on a distinguished road
Can I take a stab at exhaust leak? crappy plugs? anybody?
Old March 11th, 2011, 04:18 AM   #3
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Someone comes to your house at night an puts raw fuel inside your car?
Old March 11th, 2011, 04:26 AM   #4
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
There is a big ass grommet where your fuel fill tube goes into the tank. They get dry and leak. Go top off and see if it spills out or gets wet by there. If that is your problem, replace the grommet when you get to 1/4 tank.
It is best to drop your tank to do this. The tank and filler neck will come down together. Google for a write up.
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
Old March 11th, 2011, 09:10 AM   #5
brandon444's Avatar
91 Mustang LX 5.0
That's a little bit what I was thinking, I'll try that thanksthanks
Old March 13th, 2011, 03:19 AM   #6
brandon444's Avatar
91 Mustang LX 5.0
Ok so I got up under my car today, and that grommet is almost brand new and dry and clean around there, but I guess its the gas line maybe. Its in the middle of the car width wise, its right in front of the tank and a flexible hose runs to a fitting where from there it goes into a stiff line... so tell me what you think
Old March 13th, 2011, 03:24 AM   #7
ryanw's Avatar
1991 Ford Mustang GT
So its on the return line ?...The supply line should be the one with the fuel filter.
If have that backwards please chime in some one
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old March 13th, 2011, 03:34 AM   #8
brandon444's Avatar
91 Mustang LX 5.0
I'm not sure about it but there's gas on the underside of the car and I think its leaking or something from where I described... and why would it need a return line?
Old March 13th, 2011, 03:38 AM   #9
ryanw's Avatar
I was just trying to picture where the leak was at.....
You do know that you have fuel return line right ?
In case you didnt know...Fuel travel up your supply line by the fuel pump then what ever your engine does not use get sent back to your fuel tank....
255 fuel pump,
3:27 gears
Old March 13th, 2011, 03:43 AM   #10
brandon444's Avatar
91 Mustang LX 5.0
Ok that makes since on the return line.
Ill get more in to it tomorrow and might drop the tank
Old March 13th, 2011, 08:52 AM   #11
1991 Mustang LX 5.0
Only the newer mustangs, and other fords for that matter, have a returnless fuel system. There is a spendy part that regulates the pressure back by the tank. Was at my buddies shop when he was replacing one on an 04 Ford f150. Can't remember what it's called.
Old March 13th, 2011, 02:46 PM   #12
Dap1991's Avatar
91 GT 90 LX 5.0
Dap1991 is on a distinguished road
I have this same problem, I notice a gas smell after driving the car and before driving, towards the rear of the car. When i get home for spring break i need to check the things you guys mentioned, I was also thinking possibly my return line because I figured if it was the "to engine" line leaking it would cause low fuel pressure and it would run rough/not at all. Does that make sense?
1991 GT- All Stock
1990 LX 5.0- CAI, Shorty headers, flowmaster, Tubular Upper and Lower Control arms, Tokico HP series, Eibach Springs
Old March 13th, 2011, 03:07 PM   #13
ryanw's Avatar
im thinking that you could still have a leak on the supply line and it not effect the engine if the leak is small enough.....But fore sure check the bushing inbetween the fuel tank and filler neck
255 fuel pump,
3:27 gears
Old March 13th, 2011, 03:10 PM   #14
Dap1991's Avatar
91 GT 90 LX 5.0
Ya ill definitely be checking that, also, would the best way to find the leak would be to just crawl under the car while its running and look for spraying or dripping gas? I almost dont even wanna mess with it since the car is running fine but i figure it can only get worse.
1991 GT- All Stock
Threads Similar to: Gas smell
you smell like............ serbiandude The Clubhouse 3 September 15th, 2010 08:45 AM
I smell gas, need help. Mattd76 99-04 9 August 17th, 2010 08:12 PM
i smell bs KhaosGT The Clubhouse 7 July 3rd, 2008 01:17 AM
Oil smell. acehogg69 2005 - 2010 16 May 23rd, 2008 07:37 PM
smell oil wtf!!! orangerider32 94-95 2 April 3rd, 2008 12:08 AM
