94 mustang,88 mustang
n/a
replacing distributor cap
im replacing my distributor cap how can i make sure im putting the plugs in the same firring order
n/a
can i just place the new cap on then put the old one on top and where the plugs meet on top of each other just plug one by one
89 GT
Yep, that's the easy way to do it.
n/a
ok thanks im gonna go get it done right now hey what would be a good set of spark plug wires for a mostly stock 5.0
89 GT
Pretty much anything but the ford racing ones. I've used accel wires on relatively stock engines in the past and never had any problems.
1991 Mustang Gt 5.0
I have ford racing ones... Should i be thinking about buying another brand.
91 Mustang Gt306/Under Drive Pulleys/gt40 heads/ so many more goodies |
89 GT
I would. The FMS wires have over 1000 ohms per foot resistance. Good wires have 50 ohms per foot. You probably don't want to go as low as 50 ohms per foot with an EFI car because they can create interference with electrical components. But I would go with something more in the 150-300 ohm per foot range. Better spark, no interference with EFI stuff.
1990 mustang gt
everyone mentions that the ford racing ones have to be spaced out so they dont arc
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
89 GT
Hah, never heard that before. Maybe they use shitty insulation too. I had them on my car and never had arcing issues tho. But went with better wires and you could tell the difference when you pulled the plugs, much hotter spark.
AutoZone has Bosch wires with a lifetime warranty for about $35. I've had the same set for 12 years and have swapped them back and forth between both of my fox bodies. They may not be "performance" orientated but they are good long lasting wires and a great stock replacement. Like others, I had bad luck with a pair of the FMS ones too. Last year I got a set of Taylor Thundervolt? 8.2 and they seem good and were only $55. I don't like paying a lot for wires.
#11 | |
1991 Ford Mustang GT
But i was also reading on coils and im not sure what all those numbers mean when there talking about mill amps 200 or 300 ect.... And 70:1 turn ratio or 100:1 or 80:1 turn ratio. Im not sure what numbers i should consider good. My question is, is there a coil you recomend. 38000 volts , 42000 volts 48000 volts ect ?..... what are the pros and cons.....Some say for race others say stock replacement but have a 30% gain in power ect.... Can you go with to high of VOLTS ? wouldnt wanna burn a piston
I've had about six sets of frpp wires and I had two sets with a bad wire in them other wise no problems
1991 Mustang LX 5.0
I have MSD 50 ohm per foot wires. Can't say I've had any issues, but what are the related issues that you speak of. I would like to know what to watch out for.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1991 Mustang Gt 5.0
Im thinking of getting the MSD or the ACCEL one now. Maybe in two weeks since ill be changing my spark plugs too.
#15 | |
![]() But i take it that its not an issue for you right ?
1991 Mustang Gt 5.0
Wow i didnt know that either. So ACCEL wires are good?
Im not sure if thats what he meant...That was just a guess
1991 Mustang LX 5.0
Actually, I've never had stereo noise with these wires. My buddy did with the same wires though. We moved his power wire further away from the coil wire and it cured it.
89 GT
This is good info to know. I was on the fence about going with the 50ohm wires, read a few threads where people complained about them and decided to go with 150's. Seems like it's a crapshoot then, but if it works on some cars, then I would assume that the other cars may have had shielding or grounding issues.. Kinda like when you do an amp on a car, it's like flipping a coin if it's going to have engine noise or not, even if you use good wires, re-ground the battery and block, ect.. you can still have engine noise out of nowhere.. then you can take a crap set of wires, run them next to the power wire on the next car and be fine, lol.
#20 | |
89 GT
Threads Similar to: replacing distributor cap
| distributor help please | Atoka Jim | Classic Mustangs | 2 | August 2nd, 2010 07:29 AM |
| my distributor | Bmac89lx | 5.0 Mustangs | 3 | July 12th, 2010 04:05 PM |
| Distributor Gone Bad! | Timm10221 | 5.0 Mustangs | 5 | March 18th, 2010 05:35 PM |
| which steel distributor gear for my msd distributor? | STREET6 | 5.0 Mustangs | 0 | February 3rd, 2008 04:56 PM |
| Distributor | jaamfoster | 96-98 | 3 | April 13th, 2007 04:08 PM |
