Throttle body
Old April 25th, 2007, 11:51 PM   #1
Throttle body
If the TB opening on the intake is 70mm, do i want a 70mm Tb or a 65 mm? Sounds stupid but i have seen people run a size smaller on their intake and want to know what i should do,
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old April 26th, 2007, 01:14 AM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
Alot of engine builders will step intakes, TBs, heads so that there is less chance of "reversion", due to the starting and stopping of air as the valves open and close. I would think that after the plenum it really wouldent matter that much.
Old April 26th, 2007, 07:10 AM   #3
stang94 is on a distinguished road
Do anyone of you know what size the opening of the TrickFlow Street upper intake?
Giving Away For FREE PM ME.
FREE 351 Block, 90,xxx miles (Non roller block)
FREE 94-98 GT Hood (red)
Old May 4th, 2007, 02:47 AM   #4
ryanw's Avatar
1991 Ford Mustang GT
ryanw has a spectacular aura aboutryanw has a spectacular aura about
Ive been told that if your not running a power adder or a HP cam that a 70mm may be to big.65mm i think is just right. but if you do have a power adder then go with a 70mm
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old May 4th, 2007, 11:57 AM   #5
ScratchinFerTraction's Avatar
ScratchinFerTraction is on a distinguished road
Trickflow Street Heat is 75mm opening, I put 75mm throttle body (SUM-227215) and a Performance Mass Air Flow 75mm MAF.
Considering that I port matched my lower intake to the heads, it makes no sense to "step" the TB and loose that valuable effort. The upper intakes acting like an airbox should take care of what JBig was talking about.
Stan
Old May 4th, 2007, 12:33 PM   #6
Yep TFS is 75MM, thats intake, tb, and elbow if your a SN95
Threads Similar to: Throttle body
Throttle Body Snipe061 V6 Mustangs 8 September 11th, 2007 04:28 PM
Throttle Body autoranch 96-98 4 August 7th, 2007 09:24 PM
bbk throttle body dumps 2005 - 2010 4 March 26th, 2007 08:02 PM
new throttle body? AFtriathlete General Tech 18 March 20th, 2007 01:14 AM
throttle body noppe180 96-98 2 November 4th, 2006 06:57 AM
