94 mustang,88 mustang
n/a
buying some 3.73 gears
am buying some 3.73 gears what else should i buy in other words what else is my mechanic gonna ask for so i can order everything. also should i replace anything else while am there
2011 Malibu LTZ (Daily driver) 94 Mustang GT (Weekend toy) 88 Mustang GT (Track car)
1991 Ford Mustang GT
Get wheels bearing/ rear end rebuild kit ( trac loc rebuild )...May as well if your already in there, just my 2 cents
n/a
is there any place that sales a whole kit with all of that
I think summit does...do you have one of there mags ?
n/a
no do you think its on there website and how much would it run
I think the rear end rebuild kit is, one kit. And the trac lock rebuild is another...
$70-$150 rear end rebuild kit, depends on which brand you go with....Im still looking on the limited slip rebuild kit
Just got this kit and installed this week in the 02GT.
1986-11 Mustang 8.8" 3.73 Ratio Rear End Gear Kit With Ford Racing Gears at LRS - Same Day Shipping! Installation $$ will depend on your area. I paid $250 for the installation from a friend of a friend that does Mustang work, the going rate from other local speed shops was about $350.
1991 gt vert
no life beet me to it. i got the LMR kit with the frpp 3:73's. you will still need axle wheel bearings and seals. you also might want to get differant gear lube for the break in period and save the royal purple for after the first 500 miles.
n/a
the lmr kit looks good
http://www.latemodelrestoration.com/...ring-And-Seal- http://www.latemodelrestoration.com/...r-End-Gear-Kit so just whats in those links or what am i missing
1991 gt vert
thats it. i would rtv the diff cover rather than a gasket though. and like i said before you might want to get two bottles of regular gear lube. after the first 500 miles of a gear change you sould drain and refill the diff. that RP is 18 bucks a bottle, so i say save it for after the first change
Threads Similar to: buying some 3.73 gears
| does buying new gears really feel different just wondering? | PsnSnake_19 | 99-04 | 27 | August 21st, 2010 11:55 AM |
| buying used gears got a few questions... | Traidmarx | 5.0 Mustangs | 22 | April 18th, 2009 04:48 PM |
| buying gears | KenDogg | 2005 - 2010 | 15 | October 20th, 2008 11:06 PM |
| buying gears? | mustangrebuilder | 2005 - 2010 | 7 | August 24th, 2007 01:17 PM |
| ? (Buying Gears) | Mustang Mike | 99-04 | 2 | December 18th, 2006 10:54 AM |
