Alternator mounting question
Old March 12th, 2011, 11:21 AM   #1
HMERacing's Avatar
89 FOX/01 WS6
0@0/13.1@106
HMERacing is on a distinguished road
Just a quick question. I have a 302 in my stang It has a mezier ewp.
I do not have any of the stock acc brakets as my car was just a roller when I bought it. I was thinking of how to mount my alternator and was thinking I could hang the alternator off the bottom of a stock brack, cut off what is not needed at the top and use a turnbuckle for tension. Does anyone know if it will clear/work at all. The alt is the only thing that will be running off of the crank.
Any input is appreciated. thanks for reading.
Mike
1989 Mustang LX, 2001 Transam WS6
Originally Posted by 302Army187 View Post
I'm going to install an U pipe.
bitch is going to re route the exhaust pulse back out of the intake between intake pulses.
Old March 12th, 2011, 02:40 PM   #2
HMERacing's Avatar
89 FOX/01 WS6
0@0/13.1@106
? If not I may just try this.
Mike
Old March 12th, 2011, 10:00 PM   #3
fogged306's Avatar
89 GT
Aaron on Hardcore5.0 makes brackets for alternators and electric wp's. I believe he's on corral too, but I don't know his screenname over there. He charges $100 last time i checked.
I tried hacking up the factory bracket on mine because I have the same set-up. The crank drives the alternator only. It works, but it looked like shit.
Old March 12th, 2011, 10:18 PM   #4
I was going to mention a moroso low mount bracket but it looks like you posted one in that second pic
Old March 13th, 2011, 11:08 AM   #5
HMERacing's Avatar
89 FOX/01 WS6
0@0/13.1@106
The second pic is a homemade one. he bolted it to the head with a spacer and used flat steel as a brace. On the bottom he used a factory style slide adjustor. Not the best looking but it is functional.
Still looking for a one wire alternator that will keep things charged.
I have an electric WP, dual electric 2 speed fans, electric fuel pump (will eventually be two once I add the nitrous fuel system), Ign box, coil, Basic headlights, tails, parking, ect.
Am I going to need a massive alt? Or will a 65-75 amp work? What are your thoughts.
Mike
Old March 13th, 2011, 01:15 PM   #6
I don't have any experience with electric waterpumps or dual fuel pump setups but I do know the stock 65 amp alts with stock pullies can't handle most electric fans unless its an aftermarket that pulls low amps and flows shit for cfm so i'd say you'd need to upgrade to a 3g at least.. Skip the 95 amp and just hit the 130 and be done with it.
Old March 13th, 2011, 05:00 PM   #7
HMERacing's Avatar
89 FOX/01 WS6
0@0/13.1@106
I am thinking of just ordering this.
Tuff Stuff Performance 7068RF6G - Tuff Stuff One-Wire Alternators - Overview - SummitRacing.com
The car will see some street use, but very limited.
(I may put around 1500 a year on my TA, so this one should see a less than 100)
Mike
Old March 13th, 2011, 06:46 PM   #8
For Sale New SBF billet alternator brackets UPDATED THREAD! - Ford Mustang Forums : Corral.net Mustang Forum
Old March 13th, 2011, 06:52 PM   #9
FastStang91Lx's Avatar
1991 Mustang LX 5.0
I think the cog setup in that one pic is a little much, lol
Old March 13th, 2011, 07:22 PM   #10
fogged306's Avatar
89 GT
I agree. I wouldn't go less than a 130A either. You have to remember, all alternator ratings aren't at idle so you're not always charging at the advertised amperage. Different for each alt, but you have to be at a certain RPM to reach peak charging anyway. Depending on the alt, you could be as low as half the rating at idle.
Threads Similar to: Alternator mounting question
New Alternator Question? Chapman 99-04 2 September 18th, 2010 09:15 PM
alternator question bigdawg042891@aol.com V6 Mustangs 5 May 4th, 2010 11:35 PM
IAT sensor issues and mounting question. 5.0 street stanger 5.0 Mustangs 3 July 20th, 2009 10:57 PM
Alternator Question batlaxe 5.0 Mustangs 4 February 13th, 2009 07:51 PM
Alternator Question Imran 99-04 7 November 24th, 2008 02:56 PM
