Look Ma! My First Post!
1989 Mustang GT
11.29
Head Gasket Woes
89 Mustang GT. 306 with 9:1 compression, Edelbrock Heads, 274 HP Cam, Rollers, 255LPH pump, 42lb injectors, Procharger P1 SC, 11 lbs boost.
SCT Chip tuned at 435 hp to wheels. I keep blowing head gaskets. Air escaping into cooling system overpressurizing and tripping 16lb cap pushing all water overbaord into overflow and then from overflow onto street. Should I go with Cast heads and get rid of aluminum? Any advice would help... Thanks! |
1991 Ford Mustang GT
head studs
1991 Mustang LX 5.0
Head studs and multi layer steel (mls) gaskets like cometics. If you are untuned, I would get one done asap! The aluminum heads are not your issue.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
'89 LX 'Vert
10's or bust... Literally.
the heads/block COULD be an issue. I would have them checked out while you have the motor apart.
but +1 to head studs, and better gaskets
H/C/I 302 + nitrous for now... supercharger/turbo soon? ![]() |
I run 11psi with aluminum heads and still have the factory head gaskets. You are probably detonating under load or your heads/block are not straight? I'd figure out why before getting stronger gaskets, I'd rather lose a gasket then something else.
1992 Lx
11.39@119.24
which gaskets you running? pt1s?
Threads Similar to: Head Gasket Woes
| Head gasket. | JBIGBOOTSY | 5.0 Mustangs | 30 | May 14th, 2009 02:40 AM |
| intake manifold gasket or head gasket? | rasalibre | 5.0 Mustangs | 5 | November 26th, 2008 05:37 PM |
| Head Gasket | andres0286 | Modular Mustangs | 1 | March 3rd, 2008 07:27 PM |
| Not sure if the head gasket is bad | nasty92LX | 5.0 Mustangs | 5 | February 1st, 2008 06:58 PM |
| head gasket | paulesparza94 | 94-95 | 0 | January 24th, 2008 02:26 PM |
