1990 mustang gt
90gt uses coolant
Ok guys need some heip. I have a 90gt stock motor bbk headers v1 supercharger and it uses coolant don't see it dripping or coming out anywhere has some condensation out the pipes but not like alot but I think alittle to much. Any guesses of what this would be from I put new head gaskets intake and water pump. Any help please
89 GT
How much boost? Are you using head studs? What head gaskets?
1990 mustang gt
I got felpro gaskets I was thinking they might not be good enough I am around 7.5 pounds of boost. I got apr head bolts
1990 mustang gt
also check the heater core
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
1992 Lx
11.39@119.24
felpro makes like 9 different headgaskets, which ones is what hes asking
1990 mustang gt
The heater core is good no leaks no smell. The felpro use I guess the cheap one from advance auto part don't have the part # right off hand but I know they are nothing special
1991 Mustang LX 5.0
Did you have your heads checked the last time you blew a gasket? Did you at least use a straight edge on the block to check for warping? Cheap and boost shouldn't be in the same sentence.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1990 mustang gt
When I got the car it had blown head gaskets so I tore it apart and yes I did put a straight edge on both head and block to check this is no water in the oil but that don't mean much. I have asked around and have heard that some supercharged motor uses coolant I don't know if I believe that. It still runs good
1991 Mustang LX 5.0
I wouldn't believe that either.
89 GT
There's some guys who have head lifting problems with boost on these cars. Generally head studs cure the problem. A supercharged car that eats coolant is a supercharged car not put together right. If it had blown head gaskets when you got it, there could be a reason for it. Head bolts and cheap stock replacement gaskets could just be a bad combination on your engine because you still may have some warping even if the straight edge looked like it sat flat. I would switch it up to some head studs and give that a shot. It's a good idea to do them on a boosted car anyway.
Threads Similar to: 90gt uses coolant
| Coolant in the oil | 01dutchGT | Classic Mustangs | 9 | February 7th, 2011 12:12 PM |
| 90gt won't start has gas and spark | Jjl90gt | 5.0 Mustangs | 4 | July 29th, 2010 07:03 PM |
| Coolant still looks new? | Saleen0101 | Modular Mustangs | 2 | February 28th, 2010 09:59 PM |
| coolant leaked out of my coolant cap? | mustangracer2g | 96-98 | 20 | March 16th, 2009 01:22 AM |
| Coolant | zinc02GT | The Clubhouse | 4 | December 17th, 2008 02:44 AM |
