1990 LX hatch
fuel pump fuel pressure stuff
After I install a larger volume fuel pump should I re-adjust the press. reg., or will it keep the same pressure as with the lower volume pump?
it will keep the same pressure cause the regulator controls the pressure. besides, you talking about a high volume pump...not high pressure.
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
+1
490whp/432wtq, V2 13lbs. boost, 3.33 pulley |
Threads Similar to: fuel pump fuel pressure stuff
| Fuel Pressure Regulator Leaking Fuel | Buttaz | V6 Mustangs | 4 | August 17th, 2007 12:41 PM |
| No fuel pressure, Fuel gauge went above full and stayed. | woodz72 | 96-98 | 6 | July 10th, 2007 07:58 PM |
| fuel pump and pressure question | haloallstar | Modular Mustangs | 5 | February 22nd, 2007 09:49 PM |
| fuel pump not building pressure? | 5litercobra | 5.0 Mustangs | 17 | May 17th, 2006 12:34 AM |
