5.0 with minor problems
Old April 26th, 2007, 03:20 PM   #1
cobralini is on a distinguished road
Hello, I have a 87 GT with minor performance issues and I have a few questions.
1. In 5th gear I am running 2000 RPMS at 100 mph is this normal with stock gears?
2. My car seems to lose it's gusto past gearing past 3000 RPM, is this do a weakness in the stock ignition? It actuall would hold on until 3500 on 93 octane.
3. I bought my car used and been using 87 Octane fuel. exactly what does the pinging (detonation) sound like?
4. Will I FEEL a difference with Long Tubes compared to shorties?
5. I have never heard anyone talk much about equal length headers are they not good?
6. Is it hard to remove the H-Pipe yourself?
7. When I make a sharp left turn the right tire seems to have a wobble effect. Is that the tie rod, bushing, ...etc? I looked unfer the care and saw nothing that looked worn or broken.
8. What type of gear oil do you add to an stock 87 rear end and how.
9. How do you add trans fluid to a stock 87 manual trans?
Thanks for all your help!!
Old April 26th, 2007, 04:19 PM   #2
BrianNV is on a distinguished road
1.) In 5th gear on my car at 2000 RPM's I am going, approx. 70mph. My car is geared 3.08 at the rear.
2.) Could be that your timing isn't set right.
Old April 26th, 2007, 05:03 PM   #3
6.) depends if it is rusted. Mine was rusted. Let is soak in some wd40 or equivalent material and try getting it off then.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old April 26th, 2007, 05:12 PM   #4
TurboLX's Avatar
1988 Mustang LX Turbo
3) it sounds like your motor is ratteling and its not a very good sound to hear, its called piston slap and its loud
4) there will be a slight difference, long tubes are louder as well
8) Royal purple should do fine
Old April 26th, 2007, 05:53 PM   #5
95 gt vert
pnyboi is on a distinguished road
rearend
theres a plug on the front side of the diff. drivers side, use a 3/8 in. ratchet with short extension to take the plug out. I used a cheap manual pump to fill the rearend with lube.
95 gt vert/88 5.8 GT
Old April 26th, 2007, 05:54 PM   #6
nolife's Avatar
91GT, 88GT, 02GT
1) Does not sound right. I have 2.73 rear end in one of my Mustangs and I get 2000 rpm at 80mph in 5th. You either have something less then 2.73 (I doubt it) or your speedometer and/or tach is not accurate.
2) Your ignition may be having problems above 3000 but that is not a weakness in a working stock ignition.
9) T5 transmissions use Mercon ATF or you can use Dexron II or III ATF which is equivelent.
Old April 26th, 2007, 11:02 PM   #7
Racinjason81 is on a distinguished road
1) you gotta have the wrong speedo gear in the trans
2)check your timing and ignition parts
3)pinging sounds like rocks bouncing around in your engine
4)Longtubes are the best type of header and you should feel the diff
5)equal lengths bends can actually hurt HP when you reach a certain level of HP.
6)its pretty easy to remove an h pipe an X pipe is actually better if you plan on replacing your H
7)lift the front wheels and grab the wheel at 9 & 3oclock and check the
looseness of the tie rods
8)80 90W gear oil through a filler plug on the DS of diff
9)dex 3 ATF drain it out of drainplug on PS of trans To fill it remove the shifter and fill it through there with the filler plug out so not to overfill
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Threads Similar to: 5.0 with minor problems
minor throttle response issue usmcsawgunner 5.0 Mustangs 12 May 29th, 2007 02:13 AM
New Guy Needs Minor Help... (Post Car Pic) CBSTANG New Members Introductions 3 January 19th, 2007 01:10 PM
Minor Modifications shurb125 5.0 Mustangs 14 December 4th, 2006 01:13 PM
Hope fully minor fixes sau4u General Tech 8 April 22nd, 2006 01:28 PM
im not a minor! sAJ1420 The Clubhouse 11 October 20th, 2005 12:41 AM
