347 stroker help please
Old May 12th, 2006, 06:15 PM   #1
ttop5.0's Avatar
ttop5.0 is on a distinguished road
I've got a 85 5 liter and want to do a 347 stroker mod on it, what do i need to do?
Old May 12th, 2006, 06:27 PM   #2
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
Buy the stroker kit. Most high performance dealers carry a stroker kit of some sort. I suggest that you get all forged. The stronger the better. Then you will have to break the motor down completely and rebuild the motor swapping the internals(Rods, crank, pistons, and possibly heads if you can afford them) I would suggest also while you have the motor out take a real good look at your clutch/torque converter, rear end, and transmission. No sense in putting all that power back in if you are going to break the drivetrain using it.
Old May 12th, 2006, 07:54 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+1
Old May 12th, 2006, 11:43 PM   #4
ttop5.0's Avatar
hey thanks, any good mail order places, you guys know about other than jegs, jc, summit?
Old May 13th, 2006, 07:35 AM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Summit, DSS, CHP, etc.
Old May 13th, 2006, 08:32 AM   #6
Drgnracin72's Avatar
moved to 5.0 tech for obvious reasons
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old May 13th, 2006, 04:29 PM   #7
stang fanatic's Avatar
stang fanatic is on a distinguished road
bore block .030, line hone mains, balance reciprocating assy and install, good heads intake and carb unless you inject in case mass air only or aftermarket dfi
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old May 13th, 2006, 04:38 PM   #8
look at coast high performance...www.coasthigh.com
Old May 13th, 2006, 10:23 PM   #9
ttop5.0's Avatar
already been bored out, all new internals ,sticking with carb
Old May 14th, 2006, 08:39 AM   #10
Zak
Zak is on a distinguished road
I bought my 331 cid stroker kit from http://www.cnc-motorsports.com they have all kind of rotating assemblies, good prices & good services.. they also give you upgrading options on the screen when you choose your stroker combo, you can have assembly balancing balancing as an option, for instance. Check it out.
Threads Similar to: 347 stroker help please
Stroker Kit 101 scxc15 V6 Mustangs 5 November 4th, 2007 01:46 PM
To Stroker or Not to Stroker? That is the Question! 87StangLX General Tech 13 October 20th, 2007 11:46 AM
347 stroker mustang_s 96-98 2 August 7th, 2007 11:57 AM
347 stroker 2007calispecial 5.0 Mustangs 8 July 31st, 2007 08:55 PM
331 stroker ballzout 5.0 Mustangs 8 July 20th, 2007 05:59 PM
