alternator
i put a 100 amp one wire alternator w/ an internal voltage regulator from summit on my 89 GT. does anyone know the proper way to hook this up? also i am only getting 12.5v out of it at 800 rpm idle, i have march underdrive pulleys on it. do i need to put my stock pulleys back on? since i am running an msd ignition and coil?? thanks
YUPPERS!!!!
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
1989 Mustang GT
I was told by another buddy who had that prob was to get an external regulator and his was fine after that, and I'm running a 190amp alternator and have a spare 130amp for sale on ebay right now
![]() Ported Saleen Vortech Intake BBK 70mm t/b,BBK CAI,BBK Reg,BBK 255 Fuel Pump Hooker Super Comp Long-tube Headers Fcam Ported Motorsport J302 Heads 30# Injectors 1.6rr 80mm Mass Air 4:11 gears |
1988 Mustang GT
31.35@55
even though you have a 100amp alt. it will only charge 12.5 at idle, give it some gas and see if jumps up to about 14 to 14.5. if it does then you're fine, if not then you do have problems. an alternator only puts out certian amounts of power at idle. for example a 130 amp will only put out about 60amps at idle.
88 gt 5spd. twisted wedge 170's, tfs stage1 cam, fms 1.72rr, edey rpm air gap intake, holley 650 ultra dp, full msd ignition, BBK full length headers, off-road x-pipe, mac pro-dump exhaust, 4.10 gears, pro 5.0 short shifter |
#5 | |
Most single wire alternators need to be excited. Once you rev the car it will start charging. 12.5 volts at idle is good, mine doesn't put out anything until 2500 rpm.
Threads Similar to: alternator
| Alternator? | jonnotch | 5.0 Mustangs | 4 | October 29th, 2007 08:25 PM |
| 3G alternator.... | Casper98GT | 5.0 Mustangs | 11 | October 2nd, 2007 06:16 PM |
| alternator | mustangman0001 | 5.0 Mustangs | 5 | September 20th, 2007 11:40 PM |
| alternator | Murderjetz | V6 Mustangs | 6 | July 26th, 2007 08:53 AM |
