Possibly a purchase 90GT!!!
Old March 19th, 2011, 05:12 PM   #1
01brknGT's Avatar
2001 Mustang GT
01brknGT is on a distinguished road
Ok I went to look at this 90 gt today and it does have all the parts listed in the ad. Does have oil coming from rear of engine and has some oil on the passenger side underneath....could be just from driving maybe??? Big deal or no? Car was painted white prev cuz the black paints isnt the greatest prob maaco.
One main question I got is with the poly engine mounts and tranny mount and a B303 cam should the engine shake or should it remain pretty still in idle. I just dont want to get this and it be something like a bent rod or something like that. How could I tell if anything internal is wrong? Fuel pressure from the reg he put on said 40psi while running.
Let me know what u all think if this is a good buy.
1990 mustang gt-4000obo
SLP LM2 CATBACK
PyPES SS O/R X
ACCUFAB 70MM TB & PLENUM
PRO 5.0 SHIFTER/UPR ARMS
STEEDA SPRT SPRINGS
17X9-N-17X10.5 FR500'S
MACH 1 GRILL-N-CHIN SPOILER
FidanZa 2.1 steeda quad and adj
2001 GT>>SOLD!!!
Old March 19th, 2011, 05:14 PM   #2
01brknGT's Avatar
2001 Mustang GT
I havent looked at this one yet, but the owner said that they have had it for 7yrs.
This one is stock but looks like original paint and all
1992 Mustang GT
SLP LM2 CATBACK
PyPES SS O/R X
STEEDA SPRT SPRINGS
2001 GT>>SOLD!!!
Old March 19th, 2011, 05:37 PM   #3
POWA! 24/7 fukkers
V8POWA!'s Avatar
1 @ 1
V8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of light
the 90 comes with a lot more and its the same price...
Old March 19th, 2011, 05:46 PM   #4
Digsj7's Avatar
1993 Mustang LX
my dog runs faster...
Digsj7 will become famous soon enough
Give the guy with the 92 $3500 and have yourself a rare unmolested fox. IMO
CAI, GT40 Intake, GT40P heads, 1.72 RR, 70mm Accufab, UPR Control arms, Hedman Headers, Mac H-Pipe, Flows, Pro-5.0, 3.73 Gears, BBK caster/camber kit, Eibach springs, Subframe Connectors, 5 lug conversion,
MM+Cleavage Club Member #19
Old March 19th, 2011, 05:49 PM   #5
01brknGT's Avatar
2001 Mustang GT
well they said they are firm on the 4200, any suggestions on the 90? The guy had the reciepts on the parts purchased from summit from him and the prev owner. Also there was a wierd thing on top of the radiator with wires cant remember what he said it was for.
SLP LM2 CATBACK
PyPES SS O/R X
STEEDA SPRT SPRINGS
2001 GT>>SOLD!!!
Old March 19th, 2011, 06:09 PM   #6
Digsj7's Avatar
1993 Mustang LX
The engine should'nt buck. I don't think a b cam is that aggresive.
Double check everything! Just because he has reciepts doesn't mean that stuff is still on the car. I know guys that have been burned by that.
Old March 19th, 2011, 06:20 PM   #7
01brknGT's Avatar
2001 Mustang GT
i looked at the car and i saw trick flow engraged on the alum head, seen the ignition,intake,lt's, BBK fuel reg and gauge. Looked in the valve covers and it was clean, seen gold rockers . As far as it bucking the idle sounds fine the engine just moves quite a bit. Anything that could be major? Doesnt smoke or anything out the back smells clean.
SLP LM2 CATBACK
PyPES SS O/R X
STEEDA SPRT SPRINGS
2001 GT>>SOLD!!!
Old March 19th, 2011, 06:41 PM   #8
01brknGT's Avatar
2001 Mustang GT
another question.....near the e-brake he said that this one wire was for the tune from the prev owner. It was a wire with a red little chip on the end pretty small thing prob the size a dime. Never seen anything like that before.
SLP LM2 CATBACK
PyPES SS O/R X
STEEDA SPRT SPRINGS
2001 GT>>SOLD!!!
Old March 19th, 2011, 08:33 PM   #9
Digsj7's Avatar
1993 Mustang LX
Who knows, thats why I like "unmolested" fox's.
If it idle's fine and sounds good. If you looked it over 10 times and like it...buy it up.
I would rather try to jew the other guy down a little and take the 92. but thats me.
Old March 19th, 2011, 09:31 PM   #10
01brknGT's Avatar
2001 Mustang GT
Well I looked some stuff up and seen that a harmonic balancer could cause the engine to act that way. He said it was the cam and the poly bushing he had and it does that. I personally dont think so. Kinda wondering if from the vibrations it caused the leak possible on the rear seal and also maybe something internal.
SLP LM2 CATBACK
PyPES SS O/R X
STEEDA SPRT SPRINGS
2001 GT>>SOLD!!!
Old March 19th, 2011, 09:37 PM   #11
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
yeah, I'd grab the 92 and do what you want with it. At least you are not going to have to figure out someone else's crap and hope they built it right. If you do it yourself then you KNOW it was done right and it will last without giving you more problems and frustration.
Fixing other peoples mistakes gets old REAL QUICK!
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old March 19th, 2011, 10:00 PM   #12
rear main seal leaking is as common as black hooker.. seriouly though it's very common which is why when you do a clutch job they recommend you change the rear main seal each time because while you have the drive shaft, trans, clutch/pressure plate, fly wheel out you might as well.
Bad harmonics from a balancer that's on it's way out or is bad can and will cause the front main seal (behind the crank pulley and harmonic balancer) to leak as well as the rear main seal.
With the car idling.. stair at the balancer and see if it looks like it's wobbling at all. If so it's probably time to replace it... stocker is $70 to $80 and a nice aftermarket one go from $250 up.
I would start the car up with the hood open.. stall the guy a little bit while it warms up and gets to operational temp and see if the car runs hot.. see if it smokes at all from the oil leakage and while it's good and warm pull the oil fill cap off the valve cover and put your hand over it... if you feel lots of force then you have blow by or if puffs of smoke come out of the filler tub.
If that shits good then take it for a drive... drive it normal like you would daily. Get into some stop and go shit and then beat on it a bit then park it and let it idle some more while you bullshit and then if everythings cool no weird noise from the rear end i'd start jewing him down about the harmonic balancer and shit. Use the angle that if the balancer's bad it could wear out other parts or have prematurely warn them down already
buying a stocker is a good idea but after owning a few and wasting thousands and years of my life on this shit i've already told myself the next one I buy will be built already or at least have good heads on the shit so on one end if you go with the stocker you won't have to worry about someones hack job but with the other one you'll start out way ahead of most people
have fun and don't forget to check the torque boxes, shock towers and floor pans for damage or rust.
Old March 19th, 2011, 10:02 PM   #13
01brknGT's Avatar
2001 Mustang GT
Yeah I did that with my 95 I had ugh frustrating. I just love the way the 90 sounded with that cam.
SLP LM2 CATBACK
PyPES SS O/R X
STEEDA SPRT SPRINGS
2001 GT>>SOLD!!!
Old March 19th, 2011, 10:26 PM   #14
01brknGT's Avatar
2001 Mustang GT
so while its running put my hand over the oil filler? wont oil start shooting out from the heads? The guy did shut it off before it warmed up cuz he said he didnt have alot of gas. He said he sanded the rust in the doors and painted them, but I dont know how good of a job he did and also it was painted black prev white and you can see white in the fenders and such.
I too also wanted to get a car with mods done already especially heads. Mainly money it wold take for me to put ontop of another car that cost the same. I mean the mods alone are 3g's + haha
SLP LM2 CATBACK
PyPES SS O/R X
STEEDA SPRT SPRINGS
2001 GT>>SOLD!!!
Old March 19th, 2011, 10:59 PM   #15
ryanw's Avatar
1991 Ford Mustang GT
Oil will not come shooting out.
Tell him you will buy a gallon or two of gas to let it idel and to take it for an extended test drive.
Dont buy into bull shit excuses. if he beats around the bush not allowing you to fully check this car out ,then you need to walk away regardless of how many modds it has. That would go to show you that he's hidding some big issues that your going to be stuck with
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old March 19th, 2011, 11:38 PM   #16
01brknGT's Avatar
2001 Mustang GT
oh and he also told me that the prev owner swapped aod to a 5 speed.
SLP LM2 CATBACK
PyPES SS O/R X
STEEDA SPRT SPRINGS
2001 GT>>SOLD!!!
Old March 20th, 2011, 12:17 AM   #17
haha no oil won't come shooting out.
I wouldn't concider talking numbers with the guy unless I could take it for a spin.. the rear end could be shot in it or make noises warning you tht it's shot. The suspension could have issues hell the most common problem with these cars is the t5 transmissions so you sure as fuck need to drive it to make sure it shifts in and out of each gear properly both quickly shifts and slow shifts.. any grinding and say later because it'll need snyncros.
Whats the guys reason for selling it?
Sounds like the body's been fucked over pretty good if it's been repainted to a different color the cheap way so i'd be willing to bet after a little bit of time the previous owner's shitty bondo job will crack or rust will start showing under the paint if the car's had rust issues before and weren't taken care of properly.
Old March 20th, 2011, 12:43 AM   #18
01brknGT's Avatar
2001 Mustang GT
Yeah I wasnt planning on purchasing until I have driven it and made sure the rear and tranny were ok. I just went today to look at it. As far as the reason why he is selling is because he said he need something "better" on gas haha. He has only had it for 6mo and im pretty sure gas was high then and still is now, not to mention he had a brand new silverado extended cab in the driveway. Who knows maybe he cant afford it with that new ride haha.
SLP LM2 CATBACK
PyPES SS O/R X
STEEDA SPRT SPRINGS
2001 GT>>SOLD!!!
Old March 20th, 2011, 11:59 AM   #19
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
Buy the 90.
Old March 20th, 2011, 01:48 PM   #20
01brknGT's Avatar
2001 Mustang GT
Originally Posted by gripthenboost View Post
Buy the 90.
any reason why u say the 90?
SLP LM2 CATBACK
PyPES SS O/R X
STEEDA SPRT SPRINGS
2001 GT>>SOLD!!!
Threads Similar to: Possibly a purchase 90GT!!!
90gt uses coolant Jjl90gt 5.0 Mustangs 9 March 13th, 2011 08:09 PM
New guy looking for car, possibly notto New Members Introductions 2 September 15th, 2010 02:47 AM
90gt won't start has gas and spark Jjl90gt 5.0 Mustangs 4 July 29th, 2010 07:03 PM
Just made quite possibly the best purchase of all time Arsenal The Clubhouse 20 April 12th, 2010 02:56 PM
Possibly a new job?... 98stangv6 The Clubhouse 16 July 26th, 2008 10:29 PM
