backfire
Old May 12th, 2006, 11:03 PM   #1
ttop5.0's Avatar
ttop5.0 is on a distinguished road
backfire
ok, so i was cruising home from work today, toying with a little 4 banger acura, hit the throttle, no response other than a backfire, and the car shutting down, i have an 85 5.0 with a 650 holley vacuum sec. i had started it up again to get it home, ran nothing over 1500rpm, till i got home, thought maybe power valve ( ithinks it;s called) replaced... idles @ 2000-2300, vacuum leak maybe please help gotta get to work in the morning
Old May 13th, 2006, 01:13 AM   #2
stang fanatic's Avatar
stang fanatic is on a distinguished road
DID YOU TAKE THE CARB OFF??? TORN MOUNT GASKET??? RUN CAR AND SPRAY CARB CLEANER ARIOUND MOUNT AREA AND SUCH....FORGET A VACUUM LINE IN BACK?????
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old May 13th, 2006, 01:19 AM   #3
ttop5.0's Avatar
I don't think I forgot anything, i double checked everything, i also took the intake off just in-case, i thought vacuum leak, re-sealed with new everything and started it up, idled @2000 again, ran for about 5 minutes, and shut it off because i noticed my headers were "glowing" red hot, about 30sec. later the loudest backfire i have ever heard...
also took carb to carb shop, he jerry rigged my vacuum secondaries to mechanical, i noticed they were also stuck open, could that cause my "glowing:, .. to much fuel?.. i know thats why it backfired, right????
Old May 13th, 2006, 01:28 AM   #4
YOU GOT THAT RIGHT!!!!! HELL, IF THE ENGINE WONT SUFFICE KICKING THE SECONDS. BUY A SPRING KIT AND INSTALL A LIGHTER SPRING ON THE DIAPHRAM....TRY TO UNJERRY RIG THOSE PUPPIES!!!!
Old May 13th, 2006, 10:10 AM   #5
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
Old May 13th, 2006, 03:32 PM   #6
HINT, hint???????? it gets tough at the late hours you know...
Old May 13th, 2006, 09:59 PM   #7
ttop5.0's Avatar
torn carb mount.. i took the carb back off and looked at it and sure enouth it was torn, not all the way through though, so maybe thats it, i will find out later, thanks guys...
Old May 17th, 2006, 10:25 PM   #8
GTXRacing is on a distinguished road
Yeah be sure that vac hose that goes to the back of the carb is in. I was fixing my carb after getting all the parts on day and hooked it all back up even saw the vac hose behind the carb. Started it up smoothly, then the second I hit the gas, it started choking and coughing and stuff. So for the next 3 days looking at the heads and everything else, I found the vac hose wasn't in so plugged it in, then is revved like I accidently touched the back of a very very pissed lion that hasn't gotten any sleep for two days! LOL
THE BEAST IS FOR SALE!!!
GTX RACING & PERFORMACE CLUB OF TEXAS
Meets and greets, drag racing and good eats, you know you want it.
GTX Racing
Tony P.
214-257-3635
http://www.moddedmustangs.com/forums...vehicle&CID=43
Threads Similar to: backfire
Sluggish 94 w/backfire Flomaster_Knockoff 94-95 6 November 1st, 2007 08:46 AM
Backfire trace & fix cobradawg 5.0 Mustangs 8 September 14th, 2007 01:35 PM
88 Gt Convertible Backfire ridebmxfbm 5.0 Mustangs 22 June 11th, 2007 12:56 PM
nitrous backfire? N02coupe 94-95 2 April 2nd, 2007 05:11 PM
nitrous backfire jetmech General Tech 1 October 18th, 2006 07:57 PM
