LinkBack (1) | Thread Tools |
#1
turn signal help!
ok so me and my buddy were working on his car he recently got (90 mustang gt) and the turn signals dont work. where do I begin? is there a relay or a fuse to check? if so where at? when you go to turn it on there is nothing. no clicking or flashing in the dash whatsoever. any help would be great
thanks!
BOSS 347
1991 Mustang GT
Sloowwwww
Replace the ignition switch.
Black 'Stang Crew #1337 |
89 GT
1995 Mustang Gt
yeah dont replace the ignition switch yet, check your fuses if you have a circuit tester first. there should be a guide in the owners manual or maybe on the back of the fuse box cover to tell you which fuses are what, but i'd test them all personally.
94 5.0 302 gt
in the making
check fuses diff, then hazzard switch,even some have had a wire in the back of the headlight switch that comes out,if those dont work check the mfs (multi funtion switch,turn signal switch)
![]() performer heads 2.02 values,prw stainless roller rockers,hardend push rods, trickflow upper,lower.lunati cam 24lb injectors,75mm tb, shorty's 2.5 pipe,h pipe, into 1 chamber 40 series flowmasters, aode,410s ![]() 18inch GT500 wheels,saleen body kit |
ok, thanks I'll check thoughs. and Ill check the big round thing on the fuse block. I'll let you guys know what I find out. any other ideas of testing things just to make sure its gettign 12 volts?
BOSS 347
91 Mustang GT
1991 sliver GT
Fuses u should check first then the hazard switch.
1990 mustang gt
also check the flasher behind the radio. the one on the fuse box is for the hazard lights, and the one behind the radio is for the turn signals
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/209926-turn-signal-help.html
| Thread 1990 Turn signal problem plz help | Forums at Modded Mustangs | BoardReader | This thread | Refback | November 7th, 2011 04:20 PM | |
Threads Similar to: turn signal help!
| Turn Signal | MnrlGry01gt | 99-04 | 13 | October 16th, 2010 05:18 PM |
| turn signal | riddlee josh | Audio/Video | 3 | January 19th, 2009 10:28 PM |
| turn signal help | 97fordsixer | V6 Mustangs | 9 | October 22nd, 2008 11:32 PM |
| Turn Signal | Youngin | The Clubhouse | 11 | August 18th, 2007 09:20 PM |
| Turn Signal | CBSTANG | 99-04 | 9 | May 28th, 2007 11:38 AM |
