Turbo guys with aftermarket engine blocks
Just wondering what blocks you turbo guys are running. I'm about to start my build and I want to do it right. I really want to run more than 10lbs of boost also.
2003 Black Cobra. 2.3 whipple JLT RAI Dragon t/b 60s BAP Mafia Xcal3 MAC LTs w/ORX-pipe Borla stingers Billetflow IRS brace Eibach springs 1989 GT AFM b-31 cam crane springs 6.3 pushrods elec. W/P/fan 3:73s Manual steering tri-ax Shorties-orh-flows |
1992 Mustang Lx 5.0 347ci
11.8@115
I've been thinking of a DSS block, either them or Dart.
89 GT
DSS blocks are just prepped stock production blocks. Dart is the way to go IMO. The boss block is nice, but you cant run a 3.4" stroke and not worry about piston rock. Unless you're talking about a 9.5 deck. Then either would be fine. Just stay away from those Chinese knockoff blocks all over eBay and racingjunk. They're copies of dart blocks, but made with much weaker metal and casting comparable to pro-comp.
11.8@115
Didn't know that about DSS, I thought they were a stronger block. Looks like I'll be spending my money on Dart when the time comes.
1989 Black LX---Turbo
I'm putting togather a new Ford Racing BOSS Block 331, that I plan on running in upwards of 18 pounds of turbo boost.
Dart Blocks have got crazy expensive latley!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
11.8@115
Yeah, priced $1,900 for a block. That is high, but if you build it right once and it's money well spent.
Slow Motion... Quick reving, High compression, Big Boy 347 stroker... STROKER MOTION... |
1969 Mustang Mach 1
6.824@101.61
If you're building a serious turbo motor it's Dart /thread
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
1999 Cobra Vert
![]() iTrader: 1 reviews
Is this for a 5.0? You can run more than 10psi- I was running 12psi with gt40p heads with no issues. With E7 heads, you can probably run 15psi and be in the safe zone. Its all in the tune though. I'd be more worried about pistons/rods than the block.
Throw in a junkyard 302, make 500whp. If it blows, throw in another junkyard engine. There is a guy at The Turbo Forums that made right at 650whp with a bone stock Explorer Gt40p longblock.
2001 BMW 540i M-sport 6 speed, staggered type 66 wheels, m5 shifter, muffler delete. Replaced my Cobra as my track car...
I vote Dart SHP block. No need for the iron eagle unless you are thinking 1000+. I made 600 rwhp with a 347 in a stock block and 12 psi. I had to cut timing out and limited it to 5300 rpm's. It would have made considerably more power with more timing and higher rpm's but the stock block would have come apart. It was girdled and was great the two years or more I drove it. I pulled everything out and sold it off, the engine is n/a in a guys car and running strong still.
I would not recommend a stock block unless you don't mind changing them out every so often. I was just trying it to see if it would last. I would not do it again.
90 GT 393 5 spd, 467 rwhp 480 rwtq 92 coupe, R/S 308 5 spd 93 coupe, 2.3 5 spd
91 GT 90 LX 5.0
do you know what you were making at 12psi?
1991 GT- All Stock 1990 LX 5.0- CAI, Shorty headers, flowmaster, Tubular Upper and Lower Control arms, Tokico HP series, Eibach Springs |
1999 Cobra Vert
~420whp through an automatic with the limiter at 5300RPM.
This was just 7psi in a 4700lb truck on 20's... http://s150.photobucket.com/albums/s...t=IM000094.mp4
1969 Mustang Mach 1
6.824@101.61
he was making that power with a junk set of heads. If you build this engine with good parts, you can exceed a stock 302s limit N/A. If your going to boost a built engine with an 8.2 deck block, you're on borrowed time with a stock block.
91 Mustang GT
1991 sliver GT
Well if its a track car your going with i would go with the dart block. But honestly if its your street car, buy a junk yard 302 build it with pistons to get the compression were u can run damn near 20 psi and be safe, the usual forged rods,and gurddle for the bottom end and morros oil pickup and all additional parts. By the time you send it all to the machine shop to be balanced a blue printed you should come in just a little shy of $2,500. As long as you have the fuel and the tune theres nothing to hold you back from making at least 500hp, This is with out your cam, heads, and intake combo.
11.8@115
Why should he be worried about the piston/rods? If he's pre '93, '92 and earlier have forged pistons, and I read a few places forged rods. Whether the rods are forged or not, the factory internals will surpass what the stock block can support.
89 GT
Yep. It's cap chatter you need to be concerned with on these 2 bolt blocks. Thin main webbing, 50oz balance, and power or RPM's or both, will kill the block itself.
So a dart block (shp) 347 internals. Trick flow top end kit with 185's and a nice lil turbo sounds really good to me. Where should I buy the 347 internals at?
1999 Cobra Vert
Because i was talking about the tune. I have personally seen a '92 burn a hole in a piston and take out two rods at ~350whp because of a bad tune.
11.8@115
Oh ok, you made it sound like the internals were weak. You could ruin ANY motor with a bad tune.
Threads Similar to: Turbo guys with aftermarket engine blocks
| engine blocks | silverstang | 2005 - 2010 | 5 | November 30th, 2008 09:43 PM |
| Engine Blocks | SAGE | 94-95 | 9 | September 5th, 2008 11:45 AM |
| DSS racing engine blocks? | gregkelley | 5.0 Mustangs | 1 | April 21st, 2007 02:43 PM |
| Engine Swap: Small Blocks or Big Blocks | Speedstang302 | 5.0 Mustangs | 32 | April 15th, 2007 10:34 AM |
| Curious About Aftermarket Blocks | MySallyMI | 99-04 | 6 | September 23rd, 2006 06:58 PM |
