#21 |
1991 Ford Mustang GT
Ive heard 15psi, but dont know forsure. But you really cant go by that. Every supercharger has a max RPM it can safely spin, and that what you go by.
If you have a stock engine and you were able to run 10 psi on it and then you took that same superchager set up and put it a highly modded engine, it may only show that its putting out 5psi. Boost is left over air that isnt used, i hope all this made sence
![]() DART 331ci stroker, AFR 185 heads, Trick Flow R intake, Accufab 70mm tb, 75mm pro m Maf, 30lb injectors, jba headers, 2 1/2" x pipe flowmaster super 10 mufflers, 255 fuel pump, 3:27 gears Last edited by ryanw; March 25th, 2011 at 12:43 AM. |
#22 |
1992 Lx
11.39@119.24
over 10 lbs that tiny blower is gona be a blow dryer
#23 |
94 mustang,88 mustang
n/a
why do you say its gonna be a blow dryer
2011 Malibu LTZ (Daily driver) 94 Mustang GT (Weekend toy) 88 Mustang GT (Track car)
#24 |
i've seen one pullied to 11lbs and according to the owner anything higher was no gains due to heat etc on a dyno
#25 |
n/a
Would I be better of with a on3performance turbo
Threads Similar to: thoughts on a paxton novi 1000
| Paxton Novi 2200 | khoranic | 2005 - 2010 | 25 | January 21st, 2010 07:23 AM |
| Paxton Novi 2200 SL | shelbygt2007 | 2005 - 2010 | 3 | June 23rd, 2009 07:03 PM |
| Paxton Novi 1000 | stangless24 | 5.0 Mustangs | 44 | June 5th, 2008 10:48 PM |
