Flat tappet vs. Roller?
could someone explain the difference between Flat tappet and roller blocks? (set ups?)
Also what is the difference in performance? if nothing then why did they switch everything over to rollers?
95' GT is being reconstructed! |
Roller = less friction & higher RPM range
Flat Tappet = more friction, less allowable rpms, but better power at low rpms due to solid lifter
#3 | |
Darrell which were you talking about?
and which do you like more and why?
#5 | |
now my next question is can you convert flatt tappet to roller? how do you do that, and is it hard?
they sell the kits, or you can buy the expensive link bar lifters and that route.
yes you can convert. The conversion kit, you have to drill into your lifter valley so you can mount the crows feet thing piece, the other one takes a smidge of maching and you can drop in the link bar lifters, but they are pricey
1993 Mustang LX Vert
As far a durability and strength is it worth converting and how much do the kits cost? or would I be better of just getting a roller block?
Threads Similar to: Flat tappet vs. Roller?
| My Expedition ran a 14 flat!!! | 06RedfireGT | The Clubhouse | 19 | September 13th, 2007 01:05 PM |
| flat black? | 94v6blkndred | Visual | 36 | June 12th, 2007 11:57 PM |
| Hydrolic roller to Solid/Mechanical roller | hitorx | 5.0 Mustangs | 2 | May 14th, 2007 05:12 PM |
| roller vs. non roller block | DJKING | 5.0 Mustangs | 11 | March 29th, 2007 11:53 AM |
| Flat Lifter | Euroeater95 | 94-95 | 6 | October 13th, 2006 01:57 PM |
