died like its outta fuel
so i just bought a 93 gt from a guy that had this thing since 1996 and he had only driven it 20 mi. the last 6 yrs. believe me when i tell you its pristine....
anyway i was driving the other day and it all of the sudden cut out like it ran out of gas...i thought at first maybe it was the ignition module...checked that and then i thought it was the fuel pump because i didnt hear it turn on after i turned the key to on. i think its just the power to the pump so if anyone knows where the fuel pump's circut starts please share....and if anyone else thinks its something else please feel free to tel me. i got 2 weeks till i fly it out to hawaii so i got something to drive on base...thanks Semper FI Dean |
The fuel pump relay on a 93 is under the hood on the passenger side kind of where the MAF is. Its mounted there on the inside of the fender. If you push the valve in on the port on your fuel rail does fuel come out? If it does then you have fuel.
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller 13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock |
also, look in the trunk on the drivers side behind the plastic panels for the inertia switch.. see if its popped or not. if you think for some reason its a wiring problem, you can take your battery to the back of the car, disconnect the fuel pump cannon plug and throw the leads on there. thats a quick way to tell if its your fuel pump or something leading up to it.
92 lx 351W w/ 60 overbore holley 600cfm carb weiand stealth dual plane intake 240/246@.510 cam bbk long tube headders msd coil 5 lug axle conversion 3.55 gears mach1 style 17" rims |
i already checked the inertia switch and it was fine. i couldnt find the relay fro the life of me....thanks
SEMPER FI Dean |
my relay is under the passenger side kick panel.it shuold be clicking when you turn the ignition on.just had the same problem 2 weeks ago.it is an 89 so yours may be different.good luck
1990 LX hatch
your fuel pump relay is under your drivers seat .
it ended up that when i took out the feul pump i missed a burned wire on the holding unit that keeps the pump in place in the tank...yea 400 dollars and a self-sustained kick in the behind!
Threads Similar to: died like its outta fuel
| how much could i get outta my cougar? | BWAL | The Clubhouse | 8 | October 13th, 2007 04:35 AM |
| Im outta my HOLE | G.T. Rags | The Clubhouse | 7 | July 10th, 2007 02:39 PM |
| 4.10 and T-Loker on in 1 hr (coming outta shop) | V6boi | V6 Mustangs | 9 | March 26th, 2007 09:30 PM |
| Modding the SHIT outta my GT | trueballerisme | 2005 - 2010 | 45 | December 4th, 2006 03:03 AM |
| kicked outta school... | sAJ1420 | The Clubhouse | 15 | March 10th, 2006 04:54 PM |
