new throttle body old spacer
i jus bought the holley sytemax 2 upper and lower intake manifold and a bbk 70 mm throttle body, however i didnt get the 70mm egr spacer and im wondering how do i jus get rid of the egr spacer...? i saw one guy on here that jus had the throttle body connected to the intake manifold itself...
but can i run the throttle body with the stock spacer jus for now and still be on the safe side or will i have to get rid of it now.??
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip |
2001 svt cobra
no way (IRS)
I would think as long as the egr valve is not in the picture it would be fine. And of course your air inlet will still work
Build #1249 MM New Edge Crew Member# 6 |
the picture you saw probably had the egr system completely removed. this can be done, but it will throw off the computer. your egr has it's pros and cons. it doesn't hold a bunch of power to be gained or lost. there is some horsepower there. there is also the possibilty of raised combustion chamber temps. checks these links for more info. on egr systems:
http://www.allfordmustangs.com/forum...emp-w-egr.html http://www.fordscorpio.co.uk/egr.htm |
Threads Similar to: new throttle body old spacer
| throttle body spacer | JASonic | V6 Mustangs | 7 | October 12th, 2007 11:35 PM |
| throttle body spacer | JASonic | The Clubhouse | 11 | July 18th, 2007 08:46 PM |
| Throttle Body Spacer | MartinG83 | V6 Mustangs | 33 | January 12th, 2007 05:04 PM |
| Throttle Body Spacer.... | Mystry | 96-98 | 5 | July 29th, 2006 12:05 AM |
