Speaker problems!! - Page 4
Old April 10th, 2011, 01:02 AM   #61
fogged306's Avatar
89 GT
RE Audio is ok for the cheap stuff. It's a lot better than Jensen, but it's probably on par with Profile and TMA and brands like that. If you just want some power added, it'll get the job done. At 4 ohms a channel you'll most likely be putting around a true 35RMS to each speaker which is plenty. I've never liked the Blaupunkt stuff to be honest, but I've also never worked at a place that sold it so maybe they've improved, or maybe I've never seen the good stuff, I don't know. All I know is I've replaced a lot of blown Blaupunkt stuff over the years.
That amp's got 4GA inputs on it, but at 50A fuse rating, you can do 8GA and be fine, as long as it's true 8GA and not the cheap crap that's been floating around for the past couple years that's more insulation than copper. 4GA would be easier because the 4GA forks that come in most kits will fit those amp terminals better than 8 GA ones. Either way you go you'll be fine.
Generally yes, 1 and 2 are front and 3 and 4 are rear, but don't count on that because that's only as reliable as the guy who installed the stuff in the first place.
Old April 10th, 2011, 01:15 AM   #62
01brknGT's Avatar
2001 Mustang GT
01brknGT is on a distinguished road
yeah there is also a cable with fuse in the engine bay that has been unhooked from the battery. Made by stinger which i know is basic walmart stuff.
SLP LM2 CATBACK
PyPES SS O/R X
ACCUFAB 70MM TB & PLENUM
PRO 5.0 SHIFTER/UPR ARMS
STEEDA SPRT SPRINGS
17X9-N-17X10.5 FR500'S
MACH 1 GRILL-N-CHIN SPOILER
FidanZa 2.1 steeda quad and adj
2001 GT>>SOLD!!!
Old April 10th, 2011, 01:21 AM   #63
fogged306's Avatar
89 GT
No stinger is good stuff. If you've got monster cable RCA's and stinger power wire, you're in good shape, that's all good material.
Old April 10th, 2011, 01:38 AM   #64
01brknGT's Avatar
2001 Mustang GT
k good, there are only two rca's though. should there be 4?
SLP LM2 CATBACK
PyPES SS O/R X
STEEDA SPRT SPRINGS
2001 GT>>SOLD!!!
Old April 10th, 2011, 01:56 AM   #65
01brknGT's Avatar
2001 Mustang GT
ok just looked at it and i found a 8ga,blue wire and the end of the two rca's near the driver sie shock tower under the panel. Once i get a amp and hook those all up what will i need to unhook so my speaker are powered off the amp and not the HU.
SLP LM2 CATBACK
PyPES SS O/R X
STEEDA SPRT SPRINGS
2001 GT>>SOLD!!!
Old April 10th, 2011, 02:36 AM   #66
fogged306's Avatar
89 GT
RCA's have 2 channels per set. So if you have 2 sets of RCA's then you've got enough for a 4 channel amp. Also check to make sure your head unit has pre-outs for front and rear. Some decks have just front and sub outputs so just because there's 2 sets of RCA's doesn't automatically mean you have front and rear outputs on the head-unit. Even if it is only front, you can just hook those up and there should be a switch on the amp to select between 2 and 4 channel inputs. You'll just lose fade control that way, but it you tune it right, you'll never need fade anyway.
Check for a ground near there in the back too. If not you can easily run your own, but make sure it's a good ground free of paint and a good bolt or decent self tapping screp that isn't just in to one thin piece of sheetmetal.
You'll need either to run speaker wire directly from the crossover inputs directly to the amp (preferred way) or just unhook the wires at your deck and tie the amp in there. That's not the best way because you have more connections to go bad now, and the stock wiring is a bit thinner than decent speaker wire. I've done it like that more than a few times when it saves a bunch of time, but it's definitely not the best way. Either way you do it, make sure you cap off the speaker wires coming off the deck. If they touch each other or chassis ground you could burn the internal amp in the deck.
Old April 10th, 2011, 02:52 AM   #67
01brknGT's Avatar
2001 Mustang GT
oh i dont have two sets of rca cables i just have one set with two ends.
SLP LM2 CATBACK
PyPES SS O/R X
STEEDA SPRT SPRINGS
2001 GT>>SOLD!!!
Old April 10th, 2011, 03:01 AM   #68
fogged306's Avatar
89 GT
well in that case you might want to find out if you even have outputs for that.. those could be just for a sub (and they probably are) What deck do you have?
Old April 10th, 2011, 03:11 AM   #69
01brknGT's Avatar
2001 Mustang GT
some old eclipse looking one haha. I know that on the back it does have two sets of rca where two can plug into each. The ones i have now are plugged into one of them and the other two are capped off. I will have to get a better look tomorrow.
SLP LM2 CATBACK
PyPES SS O/R X
STEEDA SPRT SPRINGS
2001 GT>>SOLD!!!
Old April 10th, 2011, 12:53 PM   #70
fogged306's Avatar
89 GT
You'd be surprised. Eclipse headunits had the shittiest displays on them up until a couple years ago. Ones from 2008 looked like they were from 99 with their old clock looking displays, lol. They sound fantastic though and they all had higher voltage pre-outs, which means more voltage sent in to that amp, the more you can get out of the amp. Good units, crappy screens. But I would rather have a unit that had all it's engineering in sound quality than in looks anyway.
Old April 10th, 2011, 01:06 PM   #71
ryanw's Avatar
1991 Ford Mustang GT
If you ever decide to upgrade your front separates speakers id totally recommend Boston acoustics, they kick ass
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Threads Similar to: Speaker problems!!
2003 mustang gt speaker problems ratchet281 Videos 0 January 10th, 2010 08:16 PM
speaker set ups RumRunner86 5.0 Mustangs 26 July 23rd, 2009 10:46 PM
speaker help!! stang300a Audio/Video 5 December 17th, 2008 08:41 PM
NRA Speaker Regency 2007 The Clubhouse 4 October 28th, 2008 04:26 PM
anyone using these speaker? vfast The Clubhouse 0 May 17th, 2008 05:05 PM
