303 series camshafts....
Old May 15th, 2006, 11:01 PM   #1
stang fanatic's Avatar
stang fanatic is on a distinguished road
Does anyone know if you can run ANY of the 303 series camshafts with a sdi system? read somewhere no....but dont know what is correct.
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old May 16th, 2006, 02:22 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I ran an F303 cam in my 88GT with speed density and it ran fine. You have to pay attention to fuel pressure and timing to get it to run smooth. I had alot of intermittent stalling at idle before I straightened everything out.
Old May 16th, 2006, 09:21 AM   #3
IcantDo55 is on a distinguished road
Thing is SD works on Vacuume so you have to watch the lob sep so the cam does not change the vacuume to much or it will never rin right. Honestly the stock 5.0 HO cam is not that bad. Check out www.turbomustangs.com there are guys there making 1000+ HP #'s with stock cams.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old May 16th, 2006, 09:25 AM   #4
bdinfluenceCBR is on a distinguished road
Icantdo55 is right...For what it is the H.O. cam is not a bad cam there are guys making a ton of power off them..
Old May 16th, 2006, 10:01 AM   #5
well, the guy who claimed an aftermarket cam was in there has screwed me good already, so i dont believe its got a 303 cam, but im at a loss as to why ive suddeny lost approx 10' vacuum at idle. got new hoses and replaced every intake, egr and throtttle body gasket and dont believe that suddenly a valve wont close all the way.
Threads Similar to: 303 series camshafts....
BBR Stage 1 Camshafts RX Bandit 2005 - 2010 17 September 22nd, 2007 11:47 AM
A few questions about camshafts! GT/CS 2005 - 2010 3 June 21st, 2007 09:51 AM
CAMSHAFTS ADVICE - 4.6L mightyb28 99-04 3 February 19th, 2007 05:26 PM
Camshafts import party crasher 5.0 Mustangs 1 February 9th, 2007 11:44 AM
Question On Camshafts... acmillr 99-04 13 October 3rd, 2006 04:46 PM
