hunting idle
hello, new to site. ive got a 90 gt with 5 speed. i just rrebult the motor with b cam, 1.7 rr, lightly port e7s, long tube flowtechs and off road h pipe. the problem im having is with idle. its hunting up and down and then dies. runs fine when im on the throttle, and pulls strong. any help would be greatly appreciated
#2 | ||
check the plugs
new plugs, around 600 mile. been in since i replaced motor. just pulled them and they have a red tint .
'88 LX body '91 GT D/T
8.7 in the 1/8th
IAC motor???
Founder of the I don't like my shit centerd and want it back the way it was dammit! club www.myspace.com/evoalliance greatest band alive |
i changed iac with ford unit, did not change anything. last night i was looking around the web and found a mass air adjuster by ist products. they say with the b cam and long tubes ive got the air fuel ratio out of range and the computer is running from one end to the other of the tables trying to correct the problem . they say with their unit u can adjust mass air meter. has anyone ever use this or have any opinions on it. check it out at mass-air.com
I was dealing with this, and just resolved it on Saturday with my 347. It is basically due to air starvation, the IAC can't compensate enough, the engine rpm fluctuates, as does the ouput (voltage) of the alternator. The idle hunts, and unless you throttle it some to preovide more air is can stall. Mine was intermittent but I think it had to do with how I would slow down or let the engine idle down. First you may want to try to increase the idle speed, maybe try 900 rmp or so. Reset thr TPS also to .98-.99 volts. If that dosent help you can try drilling a hole in the throttle blade, start with a 1/8". I did not want to do that. I used an idle air bypass plate that was used in a Ford TSB entitled engine hard cold starts, hesitation, stalls on startup. (TSB 91-25-7). The kit listed is Ford part #f2pz-9f939-a I went to the dealer they didn't have one and it was $50.00. I went to pick-n-pull seared all the fords and found 2 of them on older Tarus's. I installed it. It basically has 2 need an seet style orfices that are the air bleeds. I opened them both about 3 turns (adjusts with 2.5mm allen) and it works great! Note the larger u shaped operning of the bypass plate faced the connector end of the IAC. If the parts department is nice they will print the TSB for you. I will try and attach a picture.
89 GT
Check out this page too. someone posted this a few weeks back and I saved it because I had the same problem with my car before I took it apart.http://www.fordmuscle.com/archives/2...in/index.shtml
thanks for the info guys, fogged 306 that was some good info i didnt even think of. i tried that but still no luck. red hot 92 i will stop by the local dealer for the plate. until then i will just idle it up with tb screw. thanks again for the help guys.
I had a hunting problem in the past and it was caused by fuel leaking past the FPR through the vacuum line directly into the upper intake. Frustrating because I went through the entire list of common problems like the 10 pin connectors, the IAB, EGR, TPS, water temp sensor, MAF, vacuum leak, and others. Looking back, I guess this was a little more then just hunting at idle, it was hunting at anything below 1500 even with some throttle applied while driving. Oh well. Good luck!
nolife hw did you find fpr leakin was vac line wet. i am just tring to rule that out . my vac line is dry. is there some other way to check.
Well I doubt that an FPR leaking through the vacuum line is a common problem but it apparently does happen
I did not find it until I had fuel dripping out of the bottom of the throttle body where the plate linkage comes through. While looking for the source of this fuel that was where it should not be, I pulled the vacuum hose for the FPR and started the car and fuel came out of it. I also had a failed FPR that was pushing about 80PSI at idle that caused hunting as well. I would say these things are far down the list of things that would cause hunting.
i have a spare fpr i know is good, i will try swaping them out. i also need to get a fpr gage
Threads Similar to: hunting idle
| Going hunting... | homebrewed | The Clubhouse | 7 | October 10th, 2007 03:00 PM |
| Deer Hunting anyone?? | 97Cobra | Videos | 4 | August 14th, 2007 12:42 AM |
| car thief hunting | DanishStallion | 99-04 | 14 | June 11th, 2007 08:32 AM |
| Prairie Dog Hunting | 69fastback | The Clubhouse | 15 | September 13th, 2006 04:52 PM |
| Idle Problems Code 1506, Idle Overspeed Error | jagstang96 | 96-98 | 3 | August 29th, 2006 04:11 AM |
