How do you change out the speedo gear?
Old May 1st, 2007, 09:29 PM   #1
1989 GT Hatch
YNOT is on a distinguished road
I have a new speedo gear (red 7T 21) in the mail for my 89' 5.0 5-speed that is going into the shop and getting Ford Racing 3.73's this Friday.
How/where do I change that speedo gear? Any links?
I was just looking after I ordered on other sites and they offer a 6T 18 and a 7T 21. I thought I needed the 21 but now I don't know.
Old May 1st, 2007, 09:58 PM   #2
fastford3388's Avatar
1991 Mustang GT
fastford3388 is on a distinguished road
Send a message via AIM to fastford3388
i'm pretty sure you just pull the speedo cable out of the tranny (it is held in by one bolt.) and there should be a c clip type thing holding it in place. I've done this atleast 5 times on autos, 5 speed should be similar.
- '90 Mustang LX-Sold "Debbie"
- '89 Mustang GT- Deceased "Lucy"
- '91 Mustang GT-70,000 mi "The Unicorn"
Old May 1st, 2007, 10:04 PM   #3
shurb125's Avatar
1993 Mustang LX Vert
shurb125 is on a distinguished road
Whoever you bought the gears from should be able to tell you what color you need. The actual gear is located at the transmission end of the speedometer cable, it is on the drivers side of the transmission, the cable is held down with a lock shaped like a "U" and is held down by a bolt that goes into the housing. Just take out that bolt, slip out the "U" shaped lock and pull the cable out and change the gear on the end, I beleive it is also held on by some sort of clip also. Hope that helps.
Old May 2nd, 2007, 09:43 AM   #4
stang fanatic's Avatar
stang fanatic is on a distinguished road
the driven gear as said before is haeld in place by a c-clip on the end of the cable. the drive gear, on the trans is retained with a spring clip and the tailshaft housing must be removed to replace the gear.
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Threads Similar to: How do you change out the speedo gear?
How can I change my speedo for 4.10's? militant54 96-98 20 October 17th, 2007 04:22 PM
Speedo Gear G.T. Rags 96-98 5 September 17th, 2007 06:58 PM
speedo change thetrooper31 V6 Mustangs 2 June 28th, 2007 01:40 PM
What Speedo Gear Do I Need? Casper98GT Modular Mustangs 1 May 24th, 2007 01:03 AM
3.73 and speedo gear untamed97stang Modular Mustangs 4 April 26th, 2007 11:31 AM
