SVT Tach not working
Old May 1st, 2007, 11:03 PM   #1
usmcsawgunner's Avatar
1993 Mustang GT
13.2 @98.54
usmcsawgunner is on a distinguished road
Send a message via Yahoo to usmcsawgunner
i took my 93 gt to the shop to get the fromt end aligned and replace the fuel pump sending unit and now my tach dosent work and they claim it wasnt thei fault....
anyway my light is coming on for the tach but its not reading and its stuck just under 3000 rpm......any help would be awesome
Old May 2nd, 2007, 08:43 PM   #2
fogged306's Avatar
89 GT
Check the tach input wire with a test light and see if it pulses rapidly when the engine is running. Or you can use a multimeter, set it to ac volts and ground the black lead. You should see 6v to 8v at idle if I remember right. Also check the power connections, I believe there is a seperate power and parking light wire depending on the model, im not sure how yours is. If they did work under the hood, they might have loosened or disconnected the tach wire. Usually that is connected at the dist.
Threads Similar to: SVT Tach not working
Tach Stopped Working.. 87 Mustang GT NoRegrets 5.0 Mustangs 2 September 2nd, 2007 05:28 PM
Tach help BoostHard1210 99-04 2 July 30th, 2007 02:31 PM
rpm tach ironhorse V6 Mustangs 14 July 14th, 2007 02:47 AM
A tach ???????? lugthug713 5.0 Mustangs 4 December 25th, 2006 03:49 AM
