87 gt convert please help
ok im a new member i have a 87 vert with stock bottom end, lightly ported e7s, complete msd ingnition the 6a box, dizzy, and blaster 2 coil, underdrive pulleys, bbk shortys, 2.5'' off road h pipe. 5 speed my question is this the ass i bought it from put bolts in the o2 sensor holes and cut them off. the car runs but not the greatest. i have a couple of question one do the o2 sensors have to go in those holes or can i redrill them farther down the pipe, also do i have to put 2 sensors in or will just one give the cpu the reading. also i bought a new dip stick but i cant get it past the headers please help me please thanks
Big timin' in a small town
I dont think it would make that big of a difference if you mounted the o2 senors a little farther down the pipe someone correct me if im worng but you will have to have both of them for the cpu to read the senors right
welcome to MM
you need to install both sensors.you could also mount them a little further
downstream also keep them somewhat near the same clocking as the stock
ok thanks neone had the trouble with the dip stick? also is that why my car is running so rich is the o2 sensors not therte so it is overloading with fuel? also i was under the car today one of the mufflers is backwards will this cause a big prob? i bought the h pipe off a guy a work already put together jackass. well i hope to hear your input thanks
I don't know exactly what you mean by having trouble with the dip stick not fitting but you can bend the shaft a little to make it fit if thats what you need to do. The muffler being on backwards??????? are you sure it's on backwards
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55, |
im very sure its on backwards one is entering in the center the other is entering in the offset i looked at them they are both the same part number. will this make it run bad also or will it just blow the baffle out? ive never came acrossed this prob. thanks
dont hold me to this but i think having the muffler backwards can make it run a little weird, but not too much. i dont know what that will do to your back pressure but you might want to fix that.
Threads Similar to: 87 gt convert please help
| convert ? | NAWG | 5.0 Mustangs | 6 | June 14th, 2007 12:10 PM |
| New convert from VA saying hi! | terigox | New Members Introductions | 13 | April 17th, 2007 05:39 AM |
| Can I convert my V6 to a V8 GT? | kobebryant | V6 Mustangs | 14 | February 6th, 2007 09:54 PM |
| 95 V6 convert V8?? | lil_kout | V6 Mustangs | 30 | December 23rd, 2006 11:18 PM |
| Convert the LX? | KingPaul | 2.3 Mustangs | 1 | November 21st, 2006 05:29 PM |
