93 5.0 notch fuel issue - Page 2
Old April 20th, 2011, 02:19 PM   #21
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
Originally Posted by Predator View Post
Ok... I'm having a similar problem with my 93 5.0 check the fuel pressure its prefect vacuum line on or off! The tps (throttle position sensor) is good!! I changed the fuel filter.. well my dad had a F-250 with a 460 with a head job, cam, and pistons pushing 400+ HP I own the truck now runs great he told me never to adjust the Distributer with a timing light it was like 36° advanced.. I put the timing light on my Mustang adjusted the timing to 10° it ran light total crap!!! Let my dad adjustedit runs alot better just still can't runt full throttle after he left I check the timing it was 30° advanced.... Next just for shits and giggles I unplugged my MAF sensor and drove it... it launched the hardest it ever has since I've owned it plug it in runs like crap ANYONE HAVE THOUGHTS ON THAT?
clean or change the maf
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old April 24th, 2011, 07:15 PM   #22
ARMY93LX's Avatar
1993 MUSTANG LX 5.0 NOTCH
unknown at this time
ARMY93LX is on a distinguished road
I have tried all of these things!
Anyone else have anything????
1993 Mustang LX 5.0
BBK cold air intake, 75mm throttle body, Cobra upper & lower, pulleys, Spec stage 2 clutch, steeda quadrant & adjustable clutch cable, A5 trans, 3.55's
Lakewood 70/30's, Eibach pro kit.
255 engine works fuel pump.
Old April 24th, 2011, 07:25 PM   #23
fogged306's Avatar
89 GT
This is the type of gauge I'm talking about. You can use any gauge as long as it's a vacuum gauge, but these kinds are cheap at harbor freight. Plus you can get a one person brake bleeder kit for them because it's also a vacuum pump.
Old April 24th, 2011, 07:27 PM   #24
FastStang91Lx's Avatar
1991 Mustang LX 5.0
What mass air meter you running? Do you have someone else's that you can try on your car? Can't remember also, but did you check your TPS not only at throttle closed and open, but through the whole range. Open it slowly and look for erratic voltage changes and not a smooth increase.
Old April 25th, 2011, 01:15 PM   #25
Predator's Avatar
1993 Mustang GT 5.0
Predator is on a distinguished road
Well all is fixed it was my MAF sensor it must have been extremely dirty I sprayed clean in it plugged it back in and it runs like never before ... Also installed electric fan for under $70, E3 Plugs $52... and swapped the 160° out for a 180° the guy that owned it before I did had the 160° in it
1993 Mustang GT 5.0 BBK cold air intake, upper and lower control arms, Ford Racing Plug Wires, Under driven pulleys, subframe connectors, King Cobra clutch, adjustable clutch cable....
Old April 25th, 2011, 04:04 PM   #26
ARMY93LX's Avatar
I have a stock mass air. I cleaned it up. same result
Put a vacuum gauge on it. It's a steady 18-19, jumps up to about 22-23 when I rev it up.
1993 Mustang LX 5.0
Old April 26th, 2011, 12:50 AM   #27
ryanw's Avatar
1991 Ford Mustang GT
Lol.... at the E3 plugs....waste of money in my opinion. Copper core all the way
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old April 26th, 2011, 12:55 AM   #28
1992 Lx
11.39@119.24
e3 plugs man better keep slicks on that beast 24/7
Old April 26th, 2011, 01:23 AM   #29
ryanw's Avatar
I'm going to start my own spark plug company I'm going to call it "SPLIT FIRE E4" and there going to have aluminum cores made from recycled beer cans with 4 ground straps.
Does any one want to buy stock in my company ? ill be charging $9.95 per plug
255 fuel pump,
3:27 gears
Old April 26th, 2011, 01:28 AM   #30
1992 Lx
11.39@119.24
Im gona invent something called an msd box for everyone to waste their money on
Old April 26th, 2011, 02:14 AM   #31
fogged306's Avatar
89 GT
I'll take 7... I heard if you don't run one plug, your car will lope like a muscle car.
Old April 26th, 2011, 07:49 PM   #32
ryanw's Avatar
That will save some of these kids some money, for those that want to do a cam change just for the sound..lol
255 fuel pump,
3:27 gears
Threads Similar to: 93 5.0 notch fuel issue
fuel pump issue 90mustang 5.0 Mustangs 4 December 25th, 2010 10:00 PM
Possible Fuel Issue WhiteVenom 99-04 65 October 7th, 2010 12:33 AM
Possible fuel issue tweety_5150 99-04 11 September 21st, 2010 04:19 PM
fuel rail issue redrocket 99-04 6 March 29th, 2010 08:23 AM
Fuel (delivery) issue?! CobraNutt 99-04 31 April 13th, 2009 01:31 PM
