tps
Old May 2nd, 2007, 05:51 PM   #1
cali 5.0 is on a distinguished road
tps
anybody no the specs on the tps sensor. i got as high as .49 and as low as .46 is that right, lost my haynes book
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip
Old May 2nd, 2007, 06:35 PM   #2
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
The recomended setting is 997-999 the best is 998 you may need to elongate the holes to allow for the extra movement to get to 998
Old May 2nd, 2007, 07:17 PM   #3
cobraetti's Avatar
2001 svt cobra
no way (IRS)
cobraetti is on a distinguished road
anywhere between .94-.99, should work just fine. Or at least it did for me
Build #1249
MM New Edge Crew Member# 6
Old May 2nd, 2007, 09:07 PM   #4
Stangzilla's Avatar
Stangzilla is on a distinguished road
Yeah take a small rat tail file or a Dremel and elongate the holes so you can acheive .94-1.05 volts. Thats what works for me but I dont know the actual spec....
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old May 2nd, 2007, 09:55 PM   #5
JBIGBOOTSY's Avatar
1990 LX hatch
Be sure to ground the voltage meter to the TPS ground and not the engine otherwise you'll get a diffrent reading
Old May 2nd, 2007, 10:00 PM   #6
stang fanatic's Avatar
stang fanatic is on a distinguished road
+1 from jbigbootsy. you have to read between the signal and return wires to get the correct reading
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old May 3rd, 2007, 12:02 AM   #7
yeh that how i read it, what does elongate mean??
and its a new bbk throttle body, should i put my old one on it and see how that works or if tht'll fix it, kus it never gave me a problem, but then again i never checked it, maybe i'll swap them and see how that works. because the car idle fine before i changed that.
Old May 3rd, 2007, 12:47 AM   #8
Stangzilla's Avatar
Well you know how the holes are round? Use a small round file to make them a little oval so you can move it a little more.. Do me a favor just look up what the word elongate means so you are clear on what it exactly means before you do it...
Old May 3rd, 2007, 09:29 AM   #9
ok...so the problem is that it doesnt idle well....how is it idling?
Old May 3rd, 2007, 11:06 AM   #10
JBIGBOOTSY's Avatar
1990 LX hatch
I tried to elongate my penis with a dremmel tool and it diden't help, and it hurt really bad!
Old May 4th, 2007, 03:33 PM   #11
sometimes it'll work jus fine, but then if i cut it off then the idle will be erratic it'll keep jumping up and down from 600 rpm to 200 and then jump rite bace up and keep doin it until it cuts off.
Old May 4th, 2007, 04:55 PM   #12
when i start it for the 1st time of everyday it runs jus fine, but if i cut it off and start it back up then it idles like shit. i took off the new tps and looked at it and it looks just like the old one except its a lil bit bigger
Old May 4th, 2007, 07:33 PM   #13
lugthug713's Avatar
2002 Roush 360R
lugthug713 is on a distinguished road
Re: tps
Good dont look for the haynes book they suck get a chiltons
Old May 4th, 2007, 10:45 PM   #14
nolife's Avatar
91GT, 88GT, 02GT
To test and adjust the TPS.
With ignition ON, engine OFF, and the TPS plugged in
1) You will need to pierce the wires with the test leads.
Measure voltage between sensor VREF (Orange wire) and SIG RTN (black wire). Voltage should be between 4.0-6.0V, if so, the correct power is getting to the sensor.
2) Measure voltage between sensor SIG RTN (black wire) and TP (green wire). Adjust the position of the TPS to achieve 0.90-0.99 volts with the throttle fully closed. After adjusting the postion of the TPS as required to get that voltage, move the throttle from closed to open and the voltage should move smoothly with the movement of the throttle plate to greater then 3.5 volts.
Old May 4th, 2007, 11:48 PM   #15
ok but how do i make the actual adjustment?
Old May 4th, 2007, 11:53 PM   #16
by loosening the tps mounting screws and turning the tps. it does sound like a iac problem though.
Old May 5th, 2007, 07:31 PM   #17
yeh but i put the holley manifold on and a new throttle body on and now it does that it idled fine before and thats not gonna go bad within a day or to, but i also had the engine running when i tested it is that the wrong way.
