largest wheels for a 1991 coupe
help me i need to know what is the largest wheel i can fit on my 1991 coupe
i have 1994 spindles on it. i bought a set if foose nitrous wheels that are 18x8.5 and they seem to stick out to far and the inside almost hit the spring. help |
#2 | |
they should fit no problem, especially if the quad shock is taken out, also you probably bought the wrong back spacing, which is why you think it sticks out too far
What is the wheel offset on your Foose's? According to 1010tires.com, the Foose Nitrous with a 34 or 38mm offset is too much offset for the 94 Mustang. Thats the distance from the mating surface to the actual center of the wheel. Which should in theory bring the outside of the wheel in further.
let me explain what i have.
my front suspension is a UPR tube k member with tube a arms and 1994 spindles the rear i have a 8.8 with 5 lug ranger axles and the car has mini tubs the front foose wheels are 18x8.5 with a 34 offset the rear foose wheels are 18x10 with a 38 offset |
and the rear is a coil over with no quad shock
Threads Similar to: largest wheels for a 1991 coupe
| 17" wheels on a 66 coupe: tires | MustangMike | Classic Mustangs | 2 | December 13th, 2009 10:17 PM |
| largest tire? | blakeasaurusrex | General Tech | 1 | August 20th, 2007 06:42 PM |
| 1991 gt aod to c4 swap?!!!!!!!!!!! | hughett17 | 5.0 Mustangs | 4 | August 16th, 2007 04:15 PM |
| 1991 LX 5.0 | yellowgt5 | 5.0 Mustangs | 6 | December 25th, 2006 10:20 AM |
