Doing Explorer intake swap, have a few questions
In the middle of doing the Explorer intake swap (the intake came off a
98 Mountanier) on our 89 5.0 and have a few problems I've come across: 1) There is a sensor that screws into the #2 runner on the 89 intake, the Explorer intake doesn't have a spot for it, will this be a problem? 2) The EGR spacer for the 89 has a small coolant hose that uses a fitting in the back of the 89 intake which the Explorer intake doesn't have, is the coolant line that necessary? 3) I removed the 89 injectors to transfer over, one has slight cracks at the tip, is that a problem? What if I used the yellow Explorer injectors, are they compatable? Sorry if these are dumb questions, use to working on the older stuff |
89 GT
That sensor is the ACT. The most ideal place to put it is in the intake piping before the throttle body somewhere. That way it doesn't get heat soaked in the intake and give inaccurate temp readings. Some people just leave it laying there next to the fuel rail. Which will work, but I like the idea if it reading the actual air temp of the air the engine is ingesting rather than ambient underhood temps.
That coolant line is for the EGR. I forget which explorer intakes had external EGR passages, but that's probably the case. I've never run an explorer intake so I couldn't give you more info about that. Can you post up a picture of the crack? is it in the cap that is removable or in the actual injector itself? |
93 vert
I drilled at tapped the #5 runner for the ACT sensor,it looks factory
![]() and in the rear I drilled and tapped for the egr coolant return(no pic) Last edited by mdbstang; April 19th, 2011 at 07:49 PM. |
#4 | |
but it's not drilled or tapped, maybe I can take it somewhere to get done or do as you suggest and mount it elsewhere. I'm not good at posted pics but it's at the tip where the fuel squirts out, looks like it may be a plastic shroud, the shroud is what's cracked. How about the o-ring's, is it critical to replace them? |
#5 | |
just not drilled or tapped for the sensor. Maybe I'll try and find a machine shop that can do it for me. |
89 GT
Either way will work. Putting it in the intake piping is easier and will give a little more accurate readings. The heat from the engine will throw the actual sensor readings off because of it's location in the manifold. They're there stock obviously, but in the 94-95 mustangs they moved it to the piping for that reason.
It depends on the shape of the o-rings. It's a good idea to replace them, but I've re-used them lots of times and had good luck. If they are cracked or dry-rotted looking, change them. If they still look smooth and don't have any flat spots or gouges taken out of them you're probably ok. If it's just that plastic cap that's cracked, you can get away with it. As long as it's the removable piece. Try to give it a tug and see if it pulls off. If it's the part I'm talking about it should slide right off the end of the injector. |
93 vert
You can add some wire and put in the intake tube also,but i wanted the factory look so i went to the hardware store and got the tap to do it myself.Get the egr return done too!
look here for your injector parts.I ran one of mine broke and it didn't hurt http://http://rjminjectiontech.com/products/inj-kit I hope i did that link correct |
1993 5.ohhhh
12.97 @140mph
Put act in intake tube
Cracked pintle caps can cause a car to run like shit Explorer injectors do work and are the same No tears in the o rings = fine.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
Anyone have pics of how they remounted the ACT?
93 vert
NOT mine,but you can see it in the intake tube right before the TB
1992 Lx
11.39@119.24
just plug it in and lay it where it is. Dam fox computer isnt gona know the difference
Threads Similar to: Doing Explorer intake swap, have a few questions
| Explorer Intake Swap Problems? | jmk7272 | 94-95 | 2 | April 25th, 2010 02:53 AM |
| Explorer intake manifold install questions. | 5.0 street stanger | 5.0 Mustangs | 26 | May 26th, 2009 12:38 AM |
| Explorer Intake Questions | fastford3388 | 5.0 Mustangs | 12 | February 20th, 2009 06:19 PM |
| Questions on vacuum set up on Explorer intake?? | MonsterSD | 5.0 Mustangs | 1 | August 17th, 2008 10:47 AM |
| explorer intake swap questions | Rustbelt | 5.0 Mustangs | 9 | October 24th, 2007 08:31 AM |
