#21 |
1993 5.ohhhh
12.97 @140mph
filter on the on oil filler neck. Get a long hose on the vacuum port and let that either aim at the ground or the valley. Put a filter on the lower intake where the pcv goes in on the lower intake manifold and block off the upper. You don't need a catch can.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
#22 | |
1989 Mustang GT 5.0
how would i attach a filter to the pcv part of the lower intake?
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
#23 |
Watttt
Tuners cover their ass.. always suggest overkill so you dont come back pointing fingers.... thats why when you get home and bust out the timing light your total timing is 24 degrees (n/a)
Butterfly Racing /211 Crew |
#24 |
1989 Mustang GT 5.0
heres my goal
400RWHP/single digit boost
#26 |
#27 |
1989 Mustang GT 5.0
6/7/8/9 lbs of boost what ever it takes to make 400
I should get the car fired up today, i have insurance on her (25) a month LOVE it, going to DMV today after work to get her registered (paper/temp plate) ehhh have to go to emissions after i get her tuned, my Magnaflow high flow cat came in today as well. put the valve covers back on motor, put the fittings on the bungs on the valve covers, mounted the breather can/catch can last night where the battery usually sits, going to relocate MSD 6AL2 box inside driver side fenderwell away from heat (since the breather can is where my MSD box used to be) throwing out washer fluid reservoir (if anyone needs it let me know) going to start mocking up downpipe and exhaust still need to wire up wideband, cruise control is gone now more polution stuff from inside passenger fenderwell is all gone, ill take some pics tonight
#28 |
Is your emissions inspection strict? In my area (not in CT), they put it on a dyno at different speeds to analyze gases and also a visual and want to see a line from the valve cover to the throttle body, charcoal canister, smog pump, the tab valves, egr etc.
#29 |
1989 Mustang GT 5.0
no its not that strict, i dont even think he opened hood the times i went before its all about that probe they put in the exhuast and run the car on rollers.
Threads Similar to: Talked to the tuner today....
| I found a 2 year old diablo tuner in my home today but... | cc250r | 99-04 | 14 | March 19th, 2011 12:58 AM |
| talked to my mechanic today | skuzzy | 96-98 | 29 | December 12th, 2009 06:45 AM |
| So I talked to the recruiter today from the Navy | Drick | The Clubhouse | 87 | January 12th, 2009 09:47 PM |
| Just talked to my dad about his truck.... | FX4DTUF | The Clubhouse | 22 | September 8th, 2008 12:08 AM |
| So I Talked To A Guy | mustang1072 | V6 Mustangs | 60 | August 16th, 2007 06:21 PM |
