93 mustang problem getting trans out
Old April 22nd, 2011, 03:12 PM   #1
GMcanblowmyFORD's Avatar
1993 stang GT
NA
GMcanblowmyFORD is on a distinguished road
well im doing a rebuild on my 302 and my trans needs rebuild too so i figured id drop the trans since i dont currently have a picker to pull everything out. so i got the exhaust off, drive shaft off, the bracket under the trans (unsure what its called) off, all the bolts holding it to the block out, block of wood under oil pan, pulled the shifter and drained it, i left the starter on but disconnected it...i cant get it to pull out..i lift up on the tail end of the trans and the motor moves with it. what am i missing??
ill still smoke honda's with no engine in my stang!
You dig the trench I lay the pipe!
Old April 22nd, 2011, 03:15 PM   #2
Watttt
EcamStr8up is on a distinguished road
Starter converter bolts
Butterfly Racing /211 Crew
Old April 22nd, 2011, 03:38 PM   #3
trevans is on a distinguished road
Yeah the starter has to come out. Also disconnect the clutch cable if it is a T5. The transmission will have to be separated from the engine a good pry bar between the engine and transmission should make them come apart just make sure all the bolts are out.
Old April 22nd, 2011, 03:39 PM   #4
'88 Mustang GT
DigitalDC89 is on a distinguished road
Send a message via AIM to DigitalDC89
auto or manual? manual shouldnt require much more then what you already took care of. the block has dowel pins to center the trans when bolting it together. those pins can practically hold the transmission itself. assuming you have removed everything securing the transmission, use a pry bar, and try to GENTLY pry the trans from the engine. if you cant, then i would suspect you missed something.
'02 Mustang GTm Convertible - N/A Cammed Daily
'88 Mustang GTm - 1/4 Mile Build - 750rwhp Project
'97 Saturn SL2m - Ex-Nitrous Build - Back-Up Daily
Old April 22nd, 2011, 03:43 PM   #5
remove the starter
Old April 22nd, 2011, 04:13 PM   #6
1993 stang GT
NA
Alright thank you for all the advice everyone, guess im pulling the starter after i eat dinner...Yeah its a t-5 clutch cable is removed and everything else disconnected
Threads Similar to: 93 mustang problem getting trans out
Trans Problem....Help Arlander 99-04 4 March 13th, 2011 05:26 PM
possible trans problem need4steed 2005 - 2010 8 February 3rd, 2011 06:59 PM
trans problem :( SlaXX 5.0 Mustangs 4 December 12th, 2010 11:08 AM
Trans problem bigtom Modular Mustangs 2 March 1st, 2009 04:39 PM
Trans Problem 97what? V6 Mustangs 0 September 10th, 2006 06:29 AM
