91 mustang factory bottom end what is piston cc
Old April 22nd, 2011, 04:44 PM   #1
tyler97's Avatar
1991 gt cobra clone
tyler97 is on a distinguished road
Im looking on a compression computer and need to know what the 91 forged piston ccs were and are they dished or dome flat or what have n0 clue
1991 GT- Ripped torque boxes/no SFCs/306/24lb injectors/Twisted Wedge 170s/Full exhaust/Full bolt ons/X3Z computer
Buid thread http://www.moddedmustangs.com/forums...ld-thread.html
Old April 22nd, 2011, 05:45 PM   #2
fogged306's Avatar
89 GT
Flat tops and as far as I've found they're 7cc valve reliefs. With the stock chambers you end up with about 9.1:1
Old April 22nd, 2011, 07:13 PM   #3
tyler97's Avatar
1991 gt cobra clone
no im running 61cc trickflow what do you think that would be.
Old April 22nd, 2011, 07:21 PM   #4
fogged306's Avatar
89 GT
Depends on a few things. But probably around 9.3 I'm guessing. If the only difference you have from stock is the heads, then it won't bump compression much. Stock E7 chambers are 63cc I believe.
Old April 22nd, 2011, 07:34 PM   #5
tyler97's Avatar
1991 gt cobra clone
no the whole tfs 365hp kit
Old April 22nd, 2011, 07:39 PM   #6
fogged306's Avatar
89 GT
I meant as far as things that will change your compression ratio, like stroke, bore, and pistons. If you're stock stroke, stock pistons, regular gasket, with those heads then that's my guess. Tough to say because I don't know how far in or out your pistons are in relation to the deck and what gasket you're using, but even then those will only vary it maybe .1 to .2 points.
Old April 22nd, 2011, 07:58 PM   #7
tyler97's Avatar
1991 gt cobra clone
I should be able to run the cam it requires 9.1 comp thats why i asked
Old April 22nd, 2011, 08:36 PM   #8
ryanw's Avatar
1991 Ford Mustang GT
stock e7 heads are 61.5 cc
Ford Head Flow Data and Specs
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Threads Similar to: 91 mustang factory bottom end what is piston cc
1985 gt mustang piston and trans question mtw002 5.0 Mustangs 3 January 6th, 2011 08:16 PM
1992 Mustang GT piston slap 92BlueStreak 5.0 Mustangs 7 December 16th, 2010 11:48 AM
2003 Mustang GT Piston & Rod Specs? RudyJ 99-04 0 June 6th, 2010 12:31 PM
WTB-NOW! FACTORY 05 Mustang GT Intake IntakeNEEDED Southwest 12 October 19th, 2007 01:07 PM
Name of Factory Alarm 96 mustang LX GafU V6 Mustangs 1 December 22nd, 2006 02:09 AM
