#41 | |
1991 gt vert
. i think thats the logic behind it. most set ups i have seen are 3-5 mm bigger on the maf.
#42 | |
1991 gt vert
their are several stock maf's listed for use in the j/y treads i posted above, but i tried one from the lincolns and it wasnt right. through my research and personal exp. the 94-95 v6 one works perfect. other than needing a flange addapter. the sn95 maf has the correct plug and the calibration is very very close to the stock fox ecu. i have had one on mine with zero issue since last november.
#43 |
Thanks guys for all the great advice.The opening on the typhoon intake is 70mm going any smaller like a 65mm would choke it correct? So the maf for 19's lbs go 75 or anything bigger than 70 than the tb? Hope i got this right haha
#44 | |
89 GT
It all depends on your goals for down the road. If you think that you'll be sticking with the typhoon for good then a 70MM or above for the MAF will work. If you think you may go bigger with your parts then you can go big on the MAF like a 90MM LMAF (lightning MAF) and a tuner. Entirely up to you on how far you think you'll take the combo and how much money and time you want to spend on it.
Here's a good read about MAF's originally posted by cgrey8 on eectuning
#45 |
Wow thanks for the good reply i have alot of reading to do. my goal is to have a street able car that can run 12's n/a. Which my mod plans are gt40p heads, trick flow,anderson cam or comp cam with the typhoon intake,long tubes(have a off road h pipe) 3:73 gears and suspension work done as well. Thanks again
#46 |
1992 Mustang GT
Yet to run
I am looking to put a cai on my 92 gt the only question i have is how do you mount up the filter on the fender wheel mount?
#47 |
1992 Mustang GT
Yet to run
I am looking at adding a cai to my 92 GT but was wondering how the filter mounts up on the fender well mounts?
#48 |
1990 mustang gt
The kit should come with everything you need
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
#49 |
^^ also just remeber where the bolts go on the fender well on the stock box. very easy
Threads Similar to: Fabricating a cold air intake for a foxbody
| 01 3.8 short ram air intake or cold air intake? | dgrazak | V6 Mustangs | 13 | May 18th, 2010 10:16 PM |
| Stock Air intake-Cold air intake | Steelsoldi3r | 96-98 | 24 | January 22nd, 2010 01:22 AM |
| short ram intake or cold air intake????? j/w | Stangbro8994 | V6 Mustangs | 32 | September 18th, 2008 08:20 PM |
| Cold Air Intake on 3.9L | 04DSGV6 | V6 Mustangs | 21 | October 8th, 2007 09:04 PM |
| Fabricating my Spintech | franchise | General Tech | 1 | January 16th, 2007 11:01 PM |
